29487 Discussions
anomalies with ASSOCIATEd names and elemental procedures
joseph_battelle
In the current compiler there are anomalies in which assignments are allowed in elemental functions when the ASSOCIATE construct is used. It seems some associated names take on host-associated status. Nesting ASSOCIATE constructs removes this status--even for actual host-associated selectors. In all cases using the selector directly instead of the associate-name inside the construct "does the right thing" even when the associate-name does not. See examples below. I haven't grok'd enough of the standard to know whether something that is "construct associated" keeps track of--or magically gains--"host association" status so my expectations below in the code may not be standard conforming.
Compiling with Intel Visual Fortran 11.1.065 [IA-32]...
[fortran]module M5
  type :: option
    integer :: id = 0
    integer :: form = 0
    logical :: multi = .false.
    integer :: code
  end type option
  integer :: hosted = 0
contains
    elemental subroutine set (opt)
        type(option), intent(inout) :: opt
        associate (f => opt% form, r => opt% code, t=>hosted)
            associate (s => opt% code, u=>hosted)
                select case (f)
                case (0) !OK; assign without using associate-name
                    opt% code = 5   ! EXPECTED as opt is not host associated
                case (1) !error #7617: This host associated object appears in a 'defining' context
                         ! in a PURE procedure or in an internal procedure contained in a PURE procedure.
                    r = 5           ! UNEXPECTED; should be same as case 0
                case (2) !OK; assign through inner-most associate-name
                    s = 5           ! removes host-associated status
                case (3) !error #7617: This host associated object appears in a 'defining' context
                    t = 5           ! EXPECTED; associate-name t is host associated
                case (4) !OK
                    u = 5           ! UNEXPECTED; expect to be same as case 3 and 5
                case (5) !error #7617: This host associated object appears in a 'defining' context
                    hosted = 5      ! EXPECTED; hosted is host associated
                end select
            end associate
        end associate
    end subroutine set
  subroutine foo()
    type(option) :: v(5)
    call set(v)
  end subroutine foo
end module[/fortran]
Escalated as issue DPD200157282. Thanks for the nice test case.
joseph_battelle
Bump. Just want to make sure this doesn't get overlooked because the compiler is definitely acting strange and inconsistently when combining associate and elemental procedures. The nested associate shows more weirdness but isn't required. The error that is forcing me to stop using associate in my code is at the first level.
Thanks - we'll take a look at this.
This was fixed in version 12.
