This little program, which I think is "legal":
Has that symbol been "mangled" correctly? I see _FRUITS_mp_NAMES in the symbol table which looks more like what I'd expect.
If I comment out the lines marked "#A" the link suceeds.
Thanks for any advice,
IanH
[fortran]MODULE Fruits
IMPLICIT NONE
PRIVATE ! #A
PUBLIC :: Get ! #A
CHARACTER(*), PARAMETER :: names(3) = [ &
'Apple ', &
'Orange ', &
'Mango ' ];
CONTAINS
FUNCTION Get(i) RESULT(s)
INTEGER, INTENT(IN) :: i
CHARACTER(LEN_TRIM(names(i))) :: s
s = names(i)
END FUNCTION Get
END MODULE Fruits
PROGRAM WheresThatbLinkingConstantGone
USE Fruits
IMPLICIT NONE
WRITE (*, "('Eat the tasty ',A)") Get(1)
END PROGRAM WheresThatbLinkingConstantGone
[/fortran] when compiled and linked using 11.1.065 with /warn:all /check:all /stand:f03 results in an unresolved external symbol error for _FRUITS_GET_mp_NAMES in _MAIN__. Has that symbol been "mangled" correctly? I see _FRUITS_mp_NAMES in the symbol table which looks more like what I'd expect.
IanH
The error message suggests that when the compiler sees the reference to "names(i)" on Line-12 it has forgotten the definition of "names" as a parameter array on Line-5, possibly as a result of a misapplication of host-association rules, specifically the attribute PRIVATE.
If "names" were undeclared, the reference to it on Line-12 would be compiled as a call to an external function "names" with argument "i", as a result of implicit typing rules coming into play.
Interesting. It's not that the compiler "forgot" but it is definitely confused. I'll report it. Thanks. Issue ID is DPD200155685.
Fixed in version 12.
