29296 Discussions
Linking errors when using memory sanitizer in fortran project
ogmundur
When I use the check uninit option in a large, mixed language (fortran and C) project with the new ifx driver I get a huge amount of the following linking errors:
undefined reference to `__msan_chain_origin'
with references to numerous other routines from the memory sanitizer all beginning with __msan. If I turn the uninit check off, the project compiles and links successfully.
I am using ifx version 2023.2.0. I am using CMake, which automatically selects ifx to link the executable.
Should I be passing further options to the linker, so that it finds the memory sanitzer routines?
Barbara_P_Intel
When you compile with -check uninit (or -check all) you also need to link with that compiler option.
Barbara_P_Intel
ogmundur
dkokron_wcoss2
What are my options for a mixed language (fortran and c++) application where some fortran code is compiled (ifx) with "-check uninit" but the application is linked with icpx (which does not recognize the -check option )?  I'm on Linux using OneAPI-2024.2.1.
Mark_Lewy
Valued Contributor I
Use "-fsanitize=memory" when compiling C/C++ to be used with "-check uninit" from ifx.
jimdempseyatthecove
If your C++ code is the main of the program, then remember to insert early into your main(...)
int argc;
char **argv;
void for_rtl_init_ (int *, char **);
for_rtl_init_ (&argc, argv);
And at the end of the program
int io_status;
int for_rtl_finish_ ( );
io_status = for_rtl_finish_ ( );
It is probably best practice in C++ to make a class or struct with the ctor doing the init and the dtor doing the finish.
Jim Dempsey
dkokron_wcoss2
Mark,
I will try that and report results back here.
Dan
