Linking problem
Clive_J_1
I have a piece of code to call the C function GetAdaptersInfo to obtain the MAC address(es) of the computer.
The (abridged) code that works is
USE IFWINTY
! define Fortran equivalents of required C structures
INTERFACE
  INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)   !                       &
 !&                                              BIND(C, NAME='GetAdaptersInfo')
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetAdaptersInfo' :: GetAdaptersInfo
  USE IFWINTY
  INTEGER (LPLONG) :: arg1
  INTEGER (LPLONG) :: arg2
  END FUNCTION GetAdaptersInfo
END INTERFACE
dwRetVal = SIZEOF(AdapterInfo)
iret = GetAdaptersInfo(LOC(AdapterInfo), LOC(dwRetVal))
However, I would prefer to do it the ISO standard way instead of using specific compiler directives so if I have tried changing the code to
USE IFWINTY
USE ISO_C_BINDING
INTERFACE
  INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)                          &
  USE IFWINTY
  USE ISO_C_BINDING
END INTERFACE
but then it fails in the linker step cannot resolve _GetAdaptersInfo
What am I doing wrong.
TIA
Clive
mecej4
If you are targeting IA32, one of the WIndows system libraries will provide the routine _GetAdaptersInfo@8, and that routine has to be called using the Stdcall convention. You provided an interface that does not correspond to any routine provided in the Windows SDKs, so you get a link-time error.
The name decoration and calling conventions for X64 are different from those for IA32, and you will need to adjust your code accordingly, if that is the platform that you wish to compile for.
Bernard
Valued Contributor I
As it was already said your code must use stdcall convention when calling Win32 API.
