I have some older FORTRAN code that was compiled into a library with CVF. Can I call those functions using Intel FORTRAN or do I need to have the CVF library rebuilt? If I can link to the CVF library can you elaborate on how that can be done.
Thank you.
Thank you.
The library will have to be rebuilt. You cannot mix object code from Intel Fortran with that of other Fortran compilers. (This is generally true across all Fortran compilers.)
Topic Options
