List-directed Output
Blane_J_
Hi. Since I am doing some fundamental calculation, this problem came up, as:
! This is good.
integer(8), parameter :: max_int64 = int(16#8000000000000000, kind = 8)
write(*,*) max_int64
! This is bad.
write(*,*) int(16#8000000000000000, kind = 8)
The upper case gives an correct output of ‭9151314442816847872‬ but the lower one prints only 0. why is that? Thanks for any help.
Steve_Lionel
I would expect these to be the same, but I can imagine why the compiler has a problem with it. Nevertheless, you are on extremely thin ice with your use of this non-standard syntax from a time when 64-bit didn't exist on the platform.  If I interpret the documentation correctly, the expected value is zero because the # syntax for "integer constants" has a kind of "default integer". I won't even start to ask why you are calling this hex value MAX_INT64 since it is not at all the maximum 64-bit integer value - indeed, it is the minimum integer value. If you truly want the largest integer value for kind 8, use HUGE(0_8).
Steve_Lionel
Blane_J_
I see, and I have found the page about "Determining the Data Type of Nondecimal Constants" in the manual. Thanks Steve and BTW, max is a mistake.
Steve_Lionel
The section you want is "Integer Constants" - the # syntax is treated differently from the BOZ syntax.
andrew_4619
      ! This is good.
      integer(8), parameter :: max_int64=int(Z'8000000000000000', kind = 8 )
      ! This is good
      write(*,*) int(Z'8000000000000000', kind = 8 )
jimdempseyatthecove
FWIW
Z'8000000000000000'
Has sign bit set and remainder bits are 0 thus representing min_int64.
(Z'8000000000000000' - 1_8) would result in sign bit 0 and remainder bits set to 1's would represent max_int64
And , -HUGE(0_8) would produce a number 1 greater than the smallest negative number.
It is disputable as to if Z'8000000000000000' represents -0, or potentially arguable as an integer NaN, though the hardware will treat this as .lt. 0.
Jim Dempsey
TimP
I believe this case, where there is a number 1 less than -huge(selected_int_kind..), isn't covered by Fortran standard. It does occur for all the usual implementations of 2's complement integer, but presents an opportunity for non-portability. Of course, the requested use of the 16# extension and the specific kind value 8 affirm the intent of non-portability.
Blane_J_
So for safely use, maybe I should turn to the boz form all the time for constants based other than 2,8,16 are not frequently used anyway. Thanks for all.
andrew_4619
The BOZ form is standards compliant so is the best way even though it seems a little clumsy at times. I aim to be able to compile any code I work on with standards checking on, it is a good thing to aim for.
mecej4
There is at least one other non-standard convention for specifying byte values for CHARACTER*1 variables:
C
      CHARACTER*1 CCR, CLF
      DATA CCR/'0D'X/, CLF/'0A'X/
Until I saw this in some old F77 code a few months ago (taken from an OS-2 code repository), I had never seen it.
