29376 Discussions
[0] DAPL startup(): RLIMIT_MEMLOCK too small
Seven_Patrick
We have 2 nodes, each with 44 cores/ intel cores. If we run a MPI program, in 1 node is ok, only the second node is ok too, “but” between the two it indicates that:
mpirun -n 80 -f machines ./wrf.exe
[1] DAPL startup(): RLIMIT_MEMLOCK too small
[2] DAPL startup(): RLIMIT_MEMLOCK too small
[3] DAPL startup(): RLIMIT_MEMLOCK too small
[4] DAPL startup(): RLIMIT_MEMLOCK too small
[5] DAPL startup(): RLIMIT_MEMLOCK too small
[6] DAPL startup(): RLIMIT_MEMLOCK too small
We followed the instructions that come in this topic ->
https://software.intel.com/en-us/blogs/2014/12/16/best-known-methods-for-setting-locked-memory-size
They do not work for us.
Intel compiler fortran is 17.0.4. gcc version 4.8.5. mpich 3.2. Oracle Linux OS 7.3.
