Locally-installed documentation for Fortran 16.0 for Windows?
TH
Newly installed updates here to Fortran 16.0 for Windows, updated from I think 14.0 or 14.1.  We don't see any locally-installed documentation (Language Reference Manual, etc.) in these installations of 16.0.  Is there a way to get locally-installed documentation for these users?  Several developers work mostly off-line and do not have access to the internet while working.  Installed version reports as:  16.0.3.207 Build 20160415. Thanks.
mecej4
There should be a directory called documentation_2016 in the root directory of the Parallel Studio installation.
Kevin_D_Intel
As noted, the content should be present under:   C:\Program Files (x86)\IntelSWTools\documentation_2016
There are various others methods for accessing it such as shortcuts from the Windows* Start menu (depending on the package installed) like:
Getting Started with Intel Parallel Studio XE 2016 Cluster Edition (Under the Parallel Studio XE 2016 program group)
Getting Started (under the Composer Edition for Fortran program group)
And also under Visual Studio under: Help > Intel Compilers and Libraries
TH
Thanks all, I see it now.
Under the Windows Programs menu 'Getting Started' is an entry for 'Training and Documentation', which points to the language reference.
Here, we all skipped past the 'Getting Started' menu item, expecting to see a direct link to the language reference in there somewhere.
Also, under Visual Studio 'Help', there is also a pretty direct link to the language reference.
Most of us are command line users who rarely open the VS interface, so thanks much for that information, we wouldn't have seen that for ages if ever.
Best regards.
dboggs
I would love to have the documentation as a local pdf file so that I can mark it up. Apparently my versions of ifort are too old to have this in the directory tree described above. Can it be made as a download from the Intel site?
dboggs
Thanks Steve. I wish I had known this several years ago. My local copy would be well red-lined and full of margin notes by now.
Steven_L_Intel1
For several years we didn't have a PDF copy, but enough customers asked for it that we did one for 16. It is linked from the FAQ.
