29298 Discussions
Location of Project Backup Settings
DavidWhite
Valued Contributor II
Where is the setting for the location of project backups? On my machine this is
P:My DocumentsVisual Studio 2005Backup FilesProject_Name
As this is a network drive, it is part of a performance problem when I am connected via VPN. I have changed all the other settings in VS2005 to point to Documents and Settings on C: but this folder is recreated every time I load and save a project.
David
Steven_L_Intel1
I had not known this VS2005 backup feature even existed! As far as I can tell, there is no way to change the location. The best I can suggest is to disable autorecover. I can't even find a registry entry for it.
DavidWhite
Thanks, Steve.
Not a perfect solution, but close. Disabling autorecover still recreates the Visual Studio 2005 folder under My Documents, but at least it is an empty folder. I guess when on VPN there will be a slight delay on load while it accesses this folder, but should not be huge.
David
Steven_L_Intel1
You could also do what I did on my laptop which was relocate My Documents to C:. Note that Windows conventions cause My Documents to be the default root for a lot of file-save activities.
DavidWhite
Unfortunately, corporate policy is for My Documents to be on a network drive with Offline files activated.
Thanks, David
DavidWhite
Steve,
Can you please investigate how VS interacts with My Documents? I raised this 18 months ago, and it is still an issue.
When connected through the VPN,my build time goes from 130 seconds to 640 seconds, even though I have all of the VS settings pointing to C:. I also have theVS settings folderset to C:, but VS appears to be waiting for or reading info fromthe network drives, even though no files are ultimately written there.
Due to corporate policy, My Documents must be on the network drive. I do, however, have all of my source code, project and solution files, intermediate files and libraries on the local machine. It does not make sense that simply having the network cable in and connected via VPN should slow the builds down so much.
David
Steven_L_Intel1
We don't have any control over this - it is strictly a Visual Studio thing. I notice that with VS08, the directory is not created or touched unless VS is exited, so perhaps the impact is less there.
DavidWhite
Steve,
This issue relates to more than simply the backup folder, but all of the folders created by VS under My DocumentsVisual Studio 2005. I do not want VS to touch My Documents under any circumstances. Are you able to confirm that VS2008 does not access My Documents (before I purchase an upgrade to VS)?
David
P.S., it is a serious performance issue with me. When working from home, I want to be connected to work via VPN for email, etc, but I do not want to be writing or even accessing network drives while I compile a project with multiple files. The performance is around 10-15%, i.e., takes 10x longer to compile while connected to the VPN. This is totally unacceptable.
Ron_Green
David,
FYI: Steve is on vacation, returning next week ( 4/20/09 )
Jugoslav_Dujic
Quoting - David White
Steve,
David
I could swear I replied to this post... maybe I closed the browser before actually clicking "add". Here we go again...
See the registry key:
HKEY_CURRENT_USERSoftwareMicrosoftVisualStudio8.0
For several directories, it points to Visual Studio 2005 folder. What happens if you change those so that they point to a local (rather than network) folder? The principal value is probably "VisualStudioLocation", pointing to the root Visual Studio 2005. Some of those are also accessible through Tools/Options/Projects and Solutions IDE dialog.
