We are currently porting an application from Digital Fortran 6.0 and have hit a problem with the MBINDEX function.
Here's a test program that demonstrates the problem:
program nls1
use ifnls
implicit none
character*20 strHelloWorld
character*4 strW
integer*4 icb
strHelloWorld = 'Hello World'
strW = 'Worl'
icb = mbindex(strHelloWorld, strW)
print *, 'MBINDEX : icb = ', icb
end program nls1
icbreturns 0butshould return 7 (which the standard "index" function does)
Also, if strW isa single character, mbindex actually corrupts the strHelloWorld string and icb returns 2.
We are currently trialling version 11.0 Build 72 running on XP SP3 x86.
It looks pretty clear cut that there's a fault in the MBINDEX function unless anyone has anysuggestions ?
Ian
program nls1
use ifnls
implicit none
character*4 strW
integer*4 icb
strW = 'Worl'
end program nls1
Ian
Does appear to be a bug with MBINDEX. Thank you for the convenient reproducer Ian. I will inquire with Development and will keep this thread updated with what I learn. (Internal tracking id: DPD200119565)
Quoting - Kevin Davis (Intel)
Fair enough. If youget a hotfix or a workaround that you want me to test, let me know.
I fail to see the advantage of MBINDEX to plain INDEX? Can someone enlighten me?
Let us take for example string S, which evaluates to "Hello " in Korean code page, and that last 4 characters take 2 bytes each. INDEX(S, '') should yield 9. (1+5+1+2 bytes for ). What is MBINDEX supposed to return? If 9, then it's no different from INDEX. If 8 (8-th actual character), that's OK, but what is programmer supposed to do with that information?
Quoting - Jugoslav Dujic
To quote from the manual:
> Performs the same function as the INDEX intrinsic function except that the strings manipulated can contain multibyte characters.
We would expect that, in your example, the return value would be 8.
I don't know the specific circumstances around the use of this function butMBINDEX certainly allows for more consistent string manipulation. For example, if you add "World" onto your example string, then MBINDEX should return the same value(which INDEX wouldn't) when searching for"Wor" regardless of the content ofcharacters 7-10.
Quoting - inaylor
My point was, why should you even know that piece of data? You are given a string which is an opaque stream of bytes. Plain INDEX returns the byte offset of the substring, and you can do some operations from that byte offset. MBINDEX returns the glyph offset, but you cannot know what those characters mean until you put it to some output renderer.
Consider:
[cpp]S = 'Hello world' i = INDEX(S, 'world') ! =10 mb = INDEX(S, 'world') ! =9 S(i:i) = 'W' !S = 'Hello World' S(mb:mb) = ??? !What to do with this? [/cpp]
I would understand function such as MBLEN or MBLEN_TRIM, which would give you number of output glyphs (e.g. for graphic output), but purpose of MBINDEX escapes me.
You can't use such positions for Fortran substring references, lacking compiler support for multibyte characters. You'd have to do all such manipulation with library routines. The reason for MBINDEX is that some encodings switch between 8 and 16 bit values depending on the character used, so simply looking for a sequence of bytes may give you the wrong answer.
I confirmed this defect is fixed in the upcoming 11.1 release (mid June).
