cDEC$ ALIAS
rre9518
I'm linking in a library which exported externals as uppercase, and I'm linking it into a application where I need lowercase.
Seems the ALIAS declaration is the best way toresolve this (right?) but when I give statement in the subroutine where I'm making the call:
cDEC$ ALIAS internalname,'INTERNALNAME'
the compiler hates it giving me a fatal error. CanALIAS handle case changes? Where is the proper place to place this statement (I put it right before the beginning of the instructions in the subroutine making the call).
What is the error? Remember that the leading "c" should be "!" if this is free-form source.
Are you using /names:lower? I strongly recommend against that.
Jugoslav_Dujic
Valued Contributor II
Quoting - rre9518
For the start, this should use a colon rather than a comma, i.e.
cDEC$ ALIAS internalname: 'INTERNALNAME'
See, however, also this recent thread. It seems that you need a full INTERFACE block for the library routine available to the caller, to make the line above work.
(The compiler manual has always been a bit fuzzy on rules of placement and the scope of !DEC$ATTRIBUTES. Apparently, it likes it in some places but not in others, but I've never really paid attention to it, as I've always placed them either as first line of a SUBROUTINE statement, or within an INTERFACE block).
Actually, comma is correct for the ALIAS directive, which predates ATTRIBUTES ALIAS. The latter uses a double-colon.
