MESSAGEBOXQQ problem
sammy
Can someone please tell me why this will not give me a New Line ( ) in a message box?
WRITE(message,'(A,I2,A)') 'Hole is less than 4" from end of plate on section #',NR,CHAR(0)
iret = MESSAGEBOXQQ(TRIM(message),'Warning'C,MB$ICONEXCLAMATION.OR.MB$OK)
anthonyrichards
New Contributor III
I use the Windows API function messsagebox(Hwnd, Message, Title, MB_ICONHAND etc. etc.)
andI find that escape sequences like , in Message don't work in that function either!
( i am using WIndows 2000, CVF6.6c)
Jugoslav_Dujic
Valued Contributor II
Escape sequences such as , etc work only if the containing string is appended with C in the code. e.g.
write(*,*) "First line Second line"C
(Note that this is a language extension). They do not work if you append char(0) by other means, such as WRITE or concatenation, e.g. the following is not equivalent:
write(*,*) "First line Second line"//char(0)
Compiler does not have a crystal ball to know how to interpret " ", i.e. whether you're going to append a char(0) or not.
In your case, you can simply use / format descriptor to obtain a new line. In more complex cases, consider sticking in char(13) or char(13)//char(10) (the latter is required for multi-line edit controls).
Jugoslav
