29386 Discussions
MPI: reorder myrank in MPI_CART_CREATE
antony_muthu__Anto_J
I have a question regarding the reordering of the processors rank when using ifort. I had a code that compiled and executed with no problems in GNU compilers. I tried the same code using ifort and it compiled without problem but is crashed during execution. I've found the problem was that just before the instruction MPI_CART_CREATE I had "reorder=.true." Replacing it by "reorder=.false." the code is executed. It also works (compile and execute) in GNU compilers.
Can anyone explain me why it fails in ifort with "reorder=.true." but works with "reorder=.false."???
Does anyone knows a way to make it work with "reorder=.true."???
Thanks a lot,
JoSo
Ron_Green
Did you build your MPI library with Intel ifort? the representation of .true. and .false. may vary by compiler. If you built MPI with gfortran it may not work when linked with an app built with ifort (and vice versa).
Hi Ronald,
Thanks for your reply. I buiklt the MPI library using a GNU compiler insted of ifort. I am also getting a segmentation fault when using ifort that I'm not getting using GNU compilers. I'll try to build MPI library using ifort.
Thanks again,
JoSo
Ron_Green
Rebuilding the MPI library with ifort should fix that issue. Now for the other seg fault, there is an article linked at the top of the main page on this forum. Read through that and try the -heap-arrays compiler option. That fixes 90% of those issues.
ron
I have rebuilt mpi with ifort and all previous problems are solved. I have a new one... which is that the results using ifort are completelly different than those obtained using GNU fortran. I'll have to find the appropriate options for ifort... wish me luck!
JoSo
