29653 Discussions
MS VS ifort generate parallel code vs disable
jimdempseyatthecove
I have a MS VS solution with a ifort project that is in the process of being converted to use OpenMP.
I created a configuration Named ReleaseOpenMP based on Release.
With the Language | Process OpenMP Directives set to Disabled
I performed a build (all files built)
Then, I changed this option to Generate Parallel Code, and performed Build
No files were rebuilt.
At this point I did not have any parallel code, but expected a rebuild to occur.
I thought this was strange (unless the IDE would scan for files containing !$omp and mark those for rebuild).
Any thoughts?
This is not affecting me, as long as I remember to build all should the occasion to do this reoccur.
Jim Dempsey
