MSC.Marc and compiler Intel XE 2015 Fortran, demonstration example e8x94c.dat
valery_z_
Hello. In MSC.Marc with the Intel XE 2015 Fortran compiler there is the demonstration example e8x94c.dat on deformation of a plate. Without use of file u8x94c.f on Fortran with the method usplit_mesh, shown below, deformation of a plate is run without a splitting of faces of the hexagon finite elements. After adding file u8x94c.f, deformation of a plate is run with a splitting of faces (written above in code in the method usplit_mesh) of hexagon finite elements.
In file u8x94c.f is declared the method usplit_mesh with ten parameters, stated below. From the theory of programming it is known, that the method usplit_mesh is not run, until it is called with a task of certain values for all ten parameters, for example with the value “1” for the variable “icall”. At running of the demonstration example e8x94c.dat on deformation of a plate with use of file u8x94c.f with method usplit_mesh, somewhere is called the method usplit_mesh with the certain values for all ten parameters, but where is called, it is unknown.
What code should be written in the method usplit_mesh, shown below, to learn, where the method usplit_mesh is called? Thanks.
      subroutine usplit_mesh(icall,nodelist,nlist,iedgelist,nedgelist,
     $     ifacelist,nfacelist,inc,time,timeinc)
#ifdef _IMPLICITNONE
      implicit none
#else
      implicit logical (a-z)
#endif
      integer nodelist,nlist,iedgelist,nedgelist,ifacelist,nfacelist
      integer icall,inc
      real*8  time,timeinc
      dimension nodelist(*),iedgelist(2,*),ifacelist(4,*)
      integer num,i,alt
      if (icall.eq.1) then
        alt=3
c  alternative 1: specify a sequence of nodes
        if (alt.eq.1) then
          nlist=7
          num=0
          do i=57,63
            num=num+1
            nodelist(num)=i
          enddo
        elseif (alt.eq.2) then
c alternative 2: specify a list of edges in any order
          nedgelist=6
          iedgelist(1,1)=57
          iedgelist(2,1)=58
          iedgelist(1,2)=62
          iedgelist(2,2)=63
          iedgelist(1,3)=59
          iedgelist(2,3)=60
          iedgelist(1,4)=58
          iedgelist(2,4)=59
          iedgelist(1,5)=60
          iedgelist(2,5)=61
          iedgelist(1,6)=61
          iedgelist(2,6)=62
        elseif (alt.eq.3) then
c  3d: give a list of faces
          nfacelist=4
          ifacelist(1,1)=819
          ifacelist(2,1)=817
          ifacelist(3,1)=822
          ifacelist(4,1)=824
c
          ifacelist(1,2)=817
          ifacelist(2,2)=57
          ifacelist(3,2)=58
          ifacelist(4,2)=822
c
          ifacelist(1,3)=829
          ifacelist(2,3)=827
          ifacelist(3,3)=822
          ifacelist(4,3)=824
c
          ifacelist(1,4)=822
          ifacelist(2,4)=827
          ifacelist(3,4)=58
          ifacelist(4,4)=59
        endif
      endif
      return
      end
Steve_Lionel
If you read that, it was incorrect. Visual Studio Express Edition has never supported anything other than Microsoft languages (and it came into existence long after Microsoft left the Fortran market.) (One could do command-line builds of Fortran, but not debugging, with Visual Studio Express Editions.)
However, Microsoft now offers Visual Studio Community Edition for free, if you qualify, and it does support Intel Fortran. You will need the latest version of Intel Parallel Studio XE 2017 (Update 4) to support Visual Studio 2017 Community Edition.
mecej4
You can add a USE IFPORT statement in the subroutine that you want and CALL TRACEBACKQQ() at a selected location in the subroutine. You may also pass optional arguments to that routine if you wish, especially if you want the program to print a traceback and continue execution; see the TRACEBACKQQ documentation for details. You should compile with the /traceback option if you use this approach and you want line numbers in the traceback.
Note that if you build a DLL with such a call to TRACEBACKQQ and that DLL is called by a package such as MARC, Fluent, etc., you may not find the traceback information to be of much use since there are no debug symbols in the caller chain.
valery_z_
Thanks for your recommendations.
On this subject on the USE IFPORT statement, I have seen the corresponding links:
https://software.intel.com/en-us/node/694591
https://software.intel.com/en-us/node/680209
https://software.intel.com/en-us/node/535322
https://software.intel.com/en-us/node/693726
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/533975
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/537434
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/270346
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/268049
https://software.intel.com/en-us/comment/1904093
https://software.intel.com/en-us/articles/the-intel-fortran-compiler-random-number-intrinsic-function-ran-may-malfunction
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/515131
In MSC.Marc with the Intel XE 2015 Fortran compiler in the usplit_mesh method, given above, after the line
#endif
I wrote the statement
USE IFPORT
and in the *.log file I received the following error message:
u8x94c.f(104): error #6278: This USE statement is not positioned correctly within the scoping unit.
      USE IFPORT
Write, please, how it is correct to write USE IFPORT and CALL TRACEBACKQQ() in the usplit_mesh method, given above? Thanks.
mecej4
See the Fortran documentation; specifically, see https://software.intel.com/en-us/node/678493 regarding the rules on the placement of USE statements.
In general, unqualified Web searches often yield too many "results" to be useful. This is especially true of searches related to the syntax rules of a programming language.
valery_z_
Following the page:
https://software.intel.com/en-us/node/694109
in the usplit_mesh method, given above, after the line:
I wrote the line:
USE IFCORE
and after the line:
        alt=3
I wrote a line:
CALL TRACEBACKQQ()
After start on running of a demonstration example of e8x94c.dat with u8x94c.f, Marc with the Intel XE 2015 Fortran compiler solved this task, however a traceback report is absent.
How to define, where the method usplit_mesh is called by specific parameters? Thanks.
mecej4
That seems to be an ill-considered location for a call to TRACEBACKQQ. What do you expect the value of ICALL to be? If that is anything different from 1, there will be no traceback printed.
It would probably be better to make the call to TRACEBACKQQ the very first executable statement in the subroutine.
valery_z_
I wrote  the line CALL TRACEBACKQQ() in different places, but there is no answer to a question.
The question remains open: Where in Marc, to the usplit_mesh method, the concrete parameters are set? Thanks.
andrew_4619
The tracebackqq report is probably sent to one of the Marc output files or alternatively into a blackhole. The environment variable FOR_DIAGNOSTIC_LOG_FILE=c:\mylog.txt can be set to direct the output to a named file.
andrew_4619
but do you even know if usplit_mesh is even called my marc in your tests? Write some output to a file to prove that.....
valery_z_
Thanks for answers.
We carry out: Marc, File, Import, Marc Input, and we import the Marc demonstration file e8x94c.dat. In a graphic window, the plate appears. We add the file u8x94c.f to the Run Job panel, and we click the Submit button. In several seconds, the solution of a task comes to an end. After the choice of commands File, Results, Open Default, Monitor results file, the plate begins to be deformed with the splitting of the faces, set above in the usplit_mesh method for alt=3.
To two files e8x94c.dat, u8x94c.f are added more the 6 files: *_job1.dat, *_job1.log, *_job1.out, *_job1.sts, *_job1.t16, *_job1.t16.mud.
What of these files to show me for you? Thanks.
mecej4
Valery, please realize that most of us do not have Marc or any other FEA, so your reporting details on running such packages is not of much use. As Andrew remarked, at this point you should focus on finding out whether or not the subroutine usplit_mesh() is called. If it is not called, the questions of where it was called from and with what arguments are pointless.
It is only after you have succeeded in getting Marc to call the subroutine that you can look at the details regarding the calling sequence and argument values. I for one, and most users in this forum probably, will not be able to help you regarding those details. You really should look for a different, Marc related, forum.
valery_z_
Thanks for answers.
In the subroutine usplit_mesh, provided above, I wrote
      write(*,*) '"icall" is:'
      write(6,*) icall
but after a task solution in Marc with the Intel XE 2015 Fortran compiler, in three files *_job1.log, *_job1.out, * _job1.sts, which can be opened in Nodepad, there is no value for “icall”?
How to me to display the value “icall”? Thanks.
mecej4
It is possible that Marc captures outputs to STDOUT. If it does, the output of WRITE(*,... statements would not appear on the console. What you can try to overcome this problem is to (i) OPEN a text file with a name such as ICALL.TXT, a unit number such as, say, 51, that is not already associated, (ii) write a message such as "ICALL - ..." to it, and close the file. If, after the Marc run, the file ICALL.TXT does not exist, that would be an indication that the subroutine was never called.
valery_z_
Thanks for answers.
Excuse me, please, but I understood nothing. Write, please, in more detail, how to answer a question:
mecej4
Add these lines of code to the subroutine, after any existing declaration statements, and run as before. Look for the file icall.log after the run.
C
      integer lun
C
      lun=0
      open(file='icall.log',newunit=lun,status='replace')
      if (lun .lt. 0) then
         write(lun,'(1x,I6,2x,A,2x,i12)')lun,'ICALL = ',icall
         close(lun)
      end if
valery_z_
Thanks for the lines of code.
In MSC.Marc with the Intel XE 2015 Fortran compiler, in file u8x94c.f, I wrote the code, which you kindly provided, in the subroutine usplit_mesh (shown above), I executed this demonstration example e8x94c.dat of Marc, in the folder C, Users, Valery, I opened the file icall.log in Notepad, and I received the record:
   -150  ICALL =              3
In this subroutine usplit_mesh from lines:
        alt=3
follows, that the parameter icall should be equal to 1. For value icall=3, the code, given in this subroutine, will not be run, but it is run.
Why the parameter icall is equal 3 in the file icall.log instead of 1? Thanks.
mecej4
Your findings in #16 establish that
  1. the subroutine usplit_mesh() is, indeed, called by Marc,
  2. The value of ICALL is not 1, as you may have expected, but 3,
  3. The subroutine has no provision for handling the case ICALL = 3
The question of why ICALL=3 is one that I cannot answer, not being a Marc user. You should, however, be able to call TRACEBACKQQ as the first statement in the subroutine and obtain a traceback listing that you can use in a Marc forum.
valery_z_
Thanks for answers.
Following the page:
in the subroutine usplit_mesh, given above, after the line:
I wrote the line:
USE IFCORE
and after the line:
        alt=3
I wrote the line:
CALL TRACEBACKQQ("My application message string")
After start on running of a demonstration example of e8x94c.dat with u8x94c.f, Marc with the Intel XE 2015 Fortran compiler stopped a solution of this task.
In the folder C, Windows, Temp appeared the file MpCmdRun.log of the following contents:
MpCmdRun: Command Line: "c:\program files\windows defender\MpCmdRun.exe" SpyNetService -RestrictPrivileges -AccessKey D9367E57-FA6C-E32D-1801-71013217DD95
 Start Time: 11:41:20
MpCmdRun: End Time: 11:41:20
Write, please, where it is correct to write the lines:
USE IFCORE
to receive the useful messages? Thanks.
andrew_4619
1] Firstly your Fortran code is only very small, attaching your code is MUCH better than using words to describe what you did
2] Please please use the {code} Fortran option (like below) to add code, it makes it readable
3] If you call TRACEBACKQQ without user_exit_code=-1 it will assume user_exit_code=0 and terminate the program.
4] With MARC user Fortran make a "test" main program so you can use the debugger to step through the code to make sure it does what you want it to before trying ruin run MARC.
4] I have added some source that should help you (and tested it)
      use ifport, only: setenvqq
      use ifcore, only: TRACEBACKQQ
      implicit none
      integer icall,inc
      real*8  time,timeinc
      integer num,i,alt
      integer lun
      logical lret
C
      lun = 0
      open( file='icall.log', newunit=lun, status='unknown',
     +      access='append' )
      if (lun /= 0) then
         write(lun,'(1x,I6,2x,A,2x,i12)') lun,'ICALL = ',icall
         close(lun)
         lret = setenvqq("FOR_DIAGNOSTIC_LOG_FILE=icall.log")
         CALL TRACEBACKQQ("My application message string",
     +                     user_exit_code=-1)
      end if
c
        alt=3
        if (alt.eq.1) then
          nlist=7
          num=0
          do i=57,63
            num=num+1
            nodelist(num)=i
          enddo
          nedgelist=6
          iedgelist(1,1)=57
          iedgelist(2,1)=58
          iedgelist(1,2)=62
          iedgelist(2,2)=63
          iedgelist(1,3)=59
          iedgelist(2,3)=60
          iedgelist(1,4)=58
          iedgelist(2,4)=59
          iedgelist(1,5)=60
          iedgelist(2,5)=61
          iedgelist(1,6)=61
          iedgelist(2,6)=62
          nfacelist=4
          ifacelist(:,1) = [819,817,822,824]
          ifacelist(:,2) = [817,57,58,822]
          ifacelist(:,3) = [829,827,822,824]
          ifacelist(:,4) = [822,827,58,59]
        endif
      endif
      return
      end
program main
      implicit none
      integer :: nlist, nedgelist, nfacelist
      integer :: nodelist(7), iedgelist(2,6), ifacelist(4,6)
      integer :: icall, inc
      real(8) ::  time, timeinc
      do ICALL = 1, 3
        call usplit_mesh(icall,nodelist,nlist,iedgelist,nedgelist,ifacelist,nfacelist,inc,time,timeinc)
      enddo
end program main
   -129  ICALL =              1
Image              PC        Routine            Line        Source
libifcoremdd.dll   5C295B1B  Unknown               Unknown  Unknown
functest.exe       008C12AA  _USPLIT_MESH               22  Source2.for
functest.exe       008C1081  _MAIN__                     8  Source1.f90
functest.exe       008C18AF  Unknown               Unknown  Unknown
functest.exe       008C4209  Unknown               Unknown  Unknown
functest.exe       008C434D  Unknown               Unknown  Unknown
KERNEL32.DLL       76F062C4  Unknown               Unknown  Unknown
ntdll.dll          77A50FD9  Unknown               Unknown  Unknown
ntdll.dll          77A50FA4  Unknown               Unknown  Unknown
   -130  ICALL =              2
   -131  ICALL =              3
valery_z_
Thanks for the code.
I inserted in Notepad the code, which you kindly provided, into the file u8x94c.f instead of the previous subroutine usplit_mesh, shown above.
After start on running of a demonstration example of e8x94c.dat with u8x94c.f, Marc with the Intel XE 2015 Fortran compiler displayed the following errors:
Default bin directory: C:\MSC.Software\Marc\2016.0.0\marc2016\bin\win64i8
Material database    : C:\MSC.Software\Marc\2016.0.0\marc2016\AF_flowmat\
ifort  /fpp /c /DWIN32_intel  -D_IMPLICITNONE /nologo /integer_size:64 -DI64 -DMKL -DOPENMP -DOMP_COMPAT -D_MSCMARC -DWIN64  /I"C:\MSC.Software\Marc\2016.0.0\marc2016\common" /I"C:\MSC.Software\Marc\2016.0.0\marc2016\bcsgpusolver\common" /I"C:\MSC.Software\Marc\2016.0.0\marc2016\mumpssolver\include" /I"C:\MSC.Software\Marc\2016.0.0\marc2016\intelmpi\win64\include" /O2 /Qip /Qvec- /Qsafe-cray-ptr /switch:fe_old_modvar /W0  /Qopenmp /Qopenmp-threadprivate:compat  -DCASI -DPARDISO -DMUMPS -DBCSGPU -DCUDA /MD -DDDM /object:"C:\Users\Valerij\u8x94c.obj"  "C:\temp\e8x94c_var26\u8x94c.f"
C:\temp\e8x94c_var26\u8x94c.f(14): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( % [ : . = =>
      C
C:\temp\e8x94c_var26\u8x94c.f(16): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( * <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> ...
C:\temp\e8x94c_var26\u8x94c.f(17): error #5276: Unbalanced parentheses
           +      access='append' )
C:\temp\e8x94c_var26\u8x94c.f(17): error #5082: Syntax error, found '+' when expecting one of: <LABEL> <END-OF-STATEMENT> ; BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX ...
           +      access='append' )
C:\temp\e8x94c_var26\u8x94c.f(22): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( * ) :: , <IDENTIFIER> <CHAR_CON_KIND_PARAM> <CHAR_NAM_KIND_PARAM> <CHARACTER_CONSTANT> ...
C:\temp\e8x94c_var26\u8x94c.f(23): error #5276: Unbalanced parentheses
C:\temp\e8x94c_var26\u8x94c.f(23): error #5082: Syntax error, found '+' when expecting one of: <LABEL> <END-OF-STATEMENT> ; BLOCK PROGRAM BLOCKDATA MODULE INTEGER REAL COMPLEX ...
C:\temp\e8x94c_var26\u8x94c.f(25): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( % [ : . = =>
      c
C:\temp\e8x94c_var26\u8x94c.f(28): error #5082: Syntax error, found IDENTIFIER 'SPECIFYASEQUENCEOFNODES' when expecting one of: BLOCK DO FORALL SELECT SELECTCASE SELECTTYPE WHERE ASSOCIATE CRITICAL IF
C:\temp\e8x94c_var26\u8x94c.f(37): error #5082: Syntax error, found IDENTIFIER 'SPECIFYALISTOFEDGESINANYORDER' when expecting one of: BLOCK DO FORALL SELECT SELECTCASE SELECTTYPE WHERE ASSOCIATE CRITICAL IF
C:\temp\e8x94c_var26\u8x94c.f(52): error #5082: Syntax error, found IDENTIFIER 'GIVEALISTOFFACES' when expecting one of: BLOCK DO FORALL SELECT SELECTCASE SELECTTYPE WHERE ASSOCIATE CRITICAL IF
C:\temp\e8x94c_var26\u8x94c.f(69): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( * ) :: , . % + - [ : . ** / // .LT. < .LE. <= .EQ. == ...
C:\temp\e8x94c_var26\u8x94c.f(69): error #6404: This name does not have a type, and must have an explicit type.   [IFACE]
compilation aborted for C:\temp\e8x94c_var26\u8x94c.f (code 1)
compile failed for C:\Users\Valerij\u8x94c.f
         Marc Exit number 3
I tried to correct independently errors, but I do not have enough knowledge of Fortran.
Help to correct errors, please. Thanks.
andrew_4619
In an old style FIXED format source file columns 1-6 are usually are usually blank and the Fortran starts in col 7. In the #19 source the $ on line 2 and the + on line 17 and 23 is in col 6 indicating a continuation line. If it is not col 6 then errors will result...
i think your source file formatting is a bit screwed. If you hover your mouse over the source in #19 a menu appears at the top right and if you click the <> icon you get a plain text popup window that you can just select all then copy paste into a Fortran file....
I also suggest it would help you if you get a primer on Fortran and do a little reading to understand basics.
