Make a static property shared between all instances of a class
S__MPay
Is it possible to define a static property that is shared between all instances of a class?
The case is a element class which uses a vector class.
I want that all element objects have a vector_i and vector_j which define the global normal vectors (i.e vector_i = vector(1, 0, 0) and vector_j = vector(0, 1, 0)).
JAlexiou
Arjen Markus wrote:
You can define a parameter in the module that contains the definition:
module vectors
module vectors
    real, dimension(3), parameter :: vector_i = [1.0, 0.0, 0.0]
end module vectors
That parameter would be available to all objects you define via this module.
FYI, The same trick works for custom types also
    type(vector3), parameter :: &
        o_ = vector3(0.0,0.0,0.0), &
        i_ = vector3(1.0,0.0,0.0), &
        j_ = vector3(0.0,1.0,0.0), &
        k_ = vector3(0.0,0.0,1.0)
PS. I use a different convention of `i_` instead of `_i`
Arjen_Markus
module vectors
module vectors
end module vectors
S__MPay
module vectors
module vectors
end module vectors
Markus, thank; but I was thinking if this may make an independent parameter for each instance and take more memory? (my concern is reduce memory usage)
Arjen_Markus
No, if you do it this way, the vectors will exist (may be an inadequate terminology) outside any object. Only when you put some component vector_i or vector_j in the class definition will they occupy memory in each one.
JAlexiou
module vectors
module vectors
end module vectors
