29487 Discussions
Meaning of "warning #7762: This procedure is recursive by default."?
AONym
New Contributor II
What is the significance of this warning message?
1>Compiling with Intel® Fortran Compiler Classic 2021.5.0 [Intel(R) 64]...
1>RationalArithmetic.f90
1>C:\Users\Username\AppData\Local\Temp\689213.i90: warning #7762: This procedure is recursive by default.
AONym
New Contributor II
Steve -
Found the cause of the error. Property page for RationalArithmetic.f90, config Debug|x64,  has /stand:f95 set; Release|x64 does not.
Steve_Lionel
I'd like to see more, including the function being defined and the compile options used.
Literally speaking, Fortran 2018, which current Intel Fortran supports, makes all procedures recursive by default. This means that you no longer have to use the RECURSIVE prefix if you call a procedure from within itself. (A new NON_RECURSIVE prefix is defined if you want to disable this.)
What I don't understand is under which circumstances the compiler would feel obligated to warn you about this. It certainly doesn't do it if you use the (now-redundant) RECURSIVE keyword. Something else must be triggering this.
JohnNichols
Honored Contributor I
So Fortran finally caught up with LISP.
AONym
New Contributor II
Steve -
I'm attaching the source. The temporary file 590813.i90 no longer exists. Here is the build log for DEBUG:
Build started: Project: MyApp_libFortran, Configuration: Debug|x64
Creating temporary file "RSP1.rsp" with contents
/nologo /debug:full /MP /Od /QaxCORE-AVX2 /Qunroll:0 /Qparallel /fpp /I"C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\include\intel64\lp64" /I"C:\MyDir\MyApp\nleqslv_libFortran\x64\Debug\Intermediate" /I"C:\MyDir\Gauss-Newton Least-Squares\x64\Debug" /I"C:\Numerical_Libraries\Numerical Recipes\x64\Debug" /DDebugLines /arch:SSE3 /extend-source:132 /noaltparam /Qopenmp /standard-semantics /Qcoarray:shared /fpscomp:nolibs /fpscomp:logicals /Qdiag-error-limit:3000 /stand:f95 /Qdiag-disable:8291 /warn:all /debug-parameters:all /Qauto /align:array64byte /Qtrapuv /fpe:0 /fpconstant /Qfp-stack-check /iface:mixed_str_len_arg /module:"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /object:"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /Fd"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\\vc170.pdb" /FAs /Fa"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /traceback /check:pointer /check:bounds /check:uninit /check:format /check:output_conversion /check:stack /libs:static /threads /dbglibs /winapp /Qmkl:parallel /c /Qsimd /Qopenmp /Qdiag-enable:15009 /Qlocation,link,"C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.30.30705\bin\HostX64\x64" /Qm64 "C:\MyDir\MyApp\MyApp_libFortran\RationalArithmetic.f90"
Creating command line "ifort @"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\RSP1.rsp""
C:\Users\Goedel\AppData\Local\Temp\590813.i90: warning #7762: This procedure is recursive by default.
MyApp_libFortran - 0 error(s), 1 warning(s)
Here is the build log for RELEASE, which does not give this warning:
Build started: Project: SedAnal_libFortran, Configuration: Release|x64
/nologo /debug:full /MP /O3 /QaxCORE-AVX2 /Qparallel /Qvec-threshold:0 /Qip /fpp /I"C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\include\intel64\lp64" /I"C:\MyDir\MyApp\nleqslv_libFortran\x64\Release" /I"C:\MyDir\Gauss-Newton Least-Squares\x64\Release" /I"C:\Numerical_Libraries\Numerical Recipes\x64\Release" /I"C:\MyDir\MyApp\nleqslv_libFortran\x64\Release" /I"C:\MyDir\Gauss-Newton Least-Squares\x64\Release" /arch:SSE3 /extend-source:132 /noaltparam /Qopenmp /standard-semantics /Qcoarray:shared /fpscomp:nolibs /fpscomp:logicals /Qdiag-error-limit:3000 /warn:all /debug-parameters:all /Qopt-report:5 /Qauto /align:dcommons /align:array64byte /align:sequence /fpe:0 /fpconstant /names:uppercase /iface:mixed_str_len_arg /module:"C:\MyDir\MyApp\MyApp_libFortran\x64\Release\Intermediate\/" /object:"C:\MyDir\MyApp\MyApp_libFortran\x64\Release\Intermediate\/" /Fd"C:\MyDir\MyApp\MyApp_libFortran\x64\Release\Intermediate\\vc170.pdb" /FAs /Fa"C:\MyDir\MyApp\MyApp_libFortran\x64\Release\Intermediate\/" /libs:static /threads /winapp /Qmkl:parallel /c /Qsimd /Qopenmp /Qopenmp-simd /Qdiag-enable:15009 /Qopt-report-format:vs /Qlocation,link,"C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.30.30705\bin\HostX64\x64" /Qm64 "C:\MyDir\MyApp\MyApp_libFortran\RationalArithmetic.f90"
Creating command line "ifort @"C:\MyDir\MyApp\MyApp_libFortran\x64\Release\Intermediate\RSP1.rsp""
ifort: remark #10397: optimization reports are generated in *.optrpt files in the output location
C:\MyDir\MyApp\MyApp_libFortran\RationalArithmetic.f90(361): remark #15009: RATIONALARITHMETIC_mp_MATMULRAT has been targeted for automatic cpu dispatch
MyApp_libFortran - 0 error(s), 0 warning(s)
jimdempseyatthecove
You are using fpp.
Add /P to command line. This should preprocess then quit.
Maybe a conflict is being introduced with fpp and token substitution.
Jim Dempsey
Steve_Lionel
OK, I got it. You enabled /stand:f95 and /standard-semantics. These two conflict a bit. /standard-semantics says to apply F2018 semantics, which includes default recursion. But then you asked for standards checking against F95, so the compiler is warning you that it applied semantics not part of F95. Subtle.
AONym
New Contributor II
Steve -
It's more subtle than you think. Using VS2022 IDE, there is no direct option for /stand:F95. However, I did find this, in Configuration Properties / Fortran / Diagnostics / General / Warn for Non-standard Fortran; it's set to "No" for both Debug and Release configurations. The description for this option appearing appearing at the bottom of the page is
Issues compile-time messages for language elements that are not standard in the Fortran 96/90/2003/2015/2018 language that can be identified at
compile-time. (/stand:{f90|f95|f03|f08|f15|f18} Property value '/stand:f15' is deprecated ad will be removed in a future release. Please use 'stand:f18' instead.
And under Command Line, it shows
 /nologo /debug:full /MP /Od /QaxCORE-AVX2 /Qunroll:0 /Qparallel /fpp /I"C:\Program Files (x86)\Intel\oneAPI\mkl\2021.1.1\include\intel64\lp64" /I"C:\MyDir\MyApp\nleqslv_libFortran\x64\Debug\Intermediate" /I"C:\MyDir\Gauss-Newton Least-Squares\x64\Debug" /I"C:\Numerical_Libraries\Numerical Recipes\x64\Debug" /DDebugLines /arch:SSE3 /extend-source:132 /noaltparam /Qopenmp /standard-semantics /Qcoarray:shared /fpscomp:nolibs /fpscomp:logicals /Qdiag-error-limit:3000 /Qdiag-disable:8291 /warn:all /debug-parameters:all /Qauto /align:array64byte /Qtrapuv /fpe:0 /fpconstant /Qfp-stack-check /iface:mixed_str_len_arg /module:"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /object:"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /Fd"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\\vc170.pdb" /FAcs /Fa"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\/" /gen-dep:"C:\MyDir\MyApp\MyApp_libFortran\x64\Debug\Intermediate\\MyApp_libFortran.dep" /traceback /check:pointer /check:bounds /check:uninit /check:format /check:output_conversion /check:stack /libs:static /threads /dbglibs /winapp /Qmkl:parallel /c
[Additional Options:]
which contains /standard-semantics, but not /stand:F95.
So, how should I remove the /stand:f95 option that is causing the unwanted warning?
andrew_4619
Out of interest try adding /stand:f18   But I don't understand your earlier post shows  the strand 95 option, I don't see how that can be based on your latest post. Have you double checked.....
AONym
New Contributor II
Andrew -
The /stand:f95 option is in the file used in the Fortran compiler command line, but not in the command line shown by VS2022 under project properties.
Steve_Lionel
I suggest that you check again - making sure you are looking at the correct configuration (Debug|x64 in the case you showed earlier). You can also ZIP the .vfproj file and attach it here so that I can look at it.
I checked VS2022, and there is both a project property for /stand:f95 and it shows in the Command Line page:
AONym
New Contributor II
Steve -
I checked again, and result is the same. Here are the Fortran settings for Debug|x64 (the configuration that gives the recursive warning):
libFortranPropertyPages.pngCommand Line shown in the configuration page includes /standard-semantics, but no other "stand" options.
But the temporary file RSP1 shown in the build log contains (in part)
Steve_Lionel
Please ZIP the .vfproj file and attach it to a new reply here. Screenshots aren't sufficient.
AONym
New Contributor II
Steve -
Steve_Lionel
See, this is why I asked for the .vfproj.  If you had provided that earlier, I would have spotted the problem immediately.
There is a tiny visual indication in the Solution Explorer for individual sources that have settings different from the project.
See that little red mark on the file icon for Console10.f90? That means it has a customized setting.
AONym
New Contributor II
Red mark--good to know.
By looking at the .vfproj file myself, I found the problem. Next time I won't have to ask!
