Minloc result in disagreement with Fortran 2003
Daniel_Dopico
Is this piece of code using minloc in disagreement with the Fortran 2003 standard?
program minloc_test
implicit none
real, dimension(2):: array = (/0., 0.2/)
integer:: pos
pos = minloc(array, 1, array < 0.)
! It should be 0 according to f2003
print *, pos
! The result is 1 with Intel Fortran 2018
end program
andrew_4619
read https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/801969
andrew_4619
Daniel_Dopico
Thank you very much Andrew!
