We have a need to write mixed language code in which we call a Fortran DLL from C code. We need to perform memory allocation in the Fortran code. We have been able to successfully allocate and access the memory, but cannot seem to figure out how to deallocate.
Could somebody help me figuring out how to convert from a integer(int_ptr_kind()) to a 'real' F90 pointer. Any help or pointers (no pun indented) are appreciated.
I have put together some sample code (see attachment). The full application will have a much more complex data structure.
Kind regards,
Gabe Haarsma
int KernelAlloc(int i,void **P2);
int KernelDeAlloc(int i,void **P2);
Based on what you said, you use Fortran subroutines as allocators/deallocators (and probably number crunching); you return the addresses of allocated arrays to a C shell, (probably for input/output purposes), right?
The problem you're encountering now is that, once you allocate in Fortran and return only the address of the array, you lose the information which is contained in Fortran array descriptor. That information is needed for later deallocation; thus, you should pass it back as well.
I wrote a C++ template class which implements VF arrays/pointers/assumed-shape arrays in C++ (keeping much of Fortran semantics), so I could post it here with a sample code, but I'd prefer your reply first before I send it, (as it's kind of work-in-progress so it's not exactly tidied up).
Jugoslav
Once again thanks for any help.
module SMOCPROWRAPPER_MODULE
contains
integer(4) function KernelCallWrapper(i,Vector)
implicit none
integer(4) :: i
real(8) :: Vector(i)
integer(4) :: j
do j=1,i
Vector(j)=j+j/10.0
end do
KernelCallWrapper=0
endfunction KernelCallWrapper
integer(4) function KernelAllocWrapper(i,PtrVector)
implicit none
integer(4) :: i
integer(int_ptr_kind()) PtrVector
real(8), pointer :: F90_PointerVector(:)
allocate(F90_PointerVector(1:i))
PtrVector=%LOC(F90_PointerVector)
KernelAllocWrapper=0
endfunction KernelAllocWrapper
integer(4) function KernelDeAllocWrapper(i,PtrVector)
implicit none
integer(4):: i
! How to deallocate PointerVector.
! How to go back from a integer(int_ptr_kind()) to a 'real' F90 Pointer,
! so we can write:
! deallocate(F90_PointerVector)
KernelDeAllocWrapper=0
endfunction KernelDeAllocWrapper
endmodule SMOCPROWRAPPER_MODULE
integer(4) function KernelCall(i,PtrVector)
use SMOCPROWRAPPER_MODULE
implicit none
!DEC$ ATTRIBUTES C,ALIAS:'_KernelCall' ::KernelCall
!DEC$ ATTRIBUTES DLLEXPORT::KernelCall
integer(4) :: i
integer(int_ptr_kind()) :: PtrVector
KernelCall=KernelCallWrapper(i,%val(PtrVector))
integer(4) function KernelAlloc(i,PtrVector)
implicit none
!DEC$ ATTRIBUTES C,ALIAS:'_KernelAlloc' ::KernelAlloc
!DEC$ ATTRIBUTES DLLEXPORT::KernelAlloc
integer(4) :: i
KernelAlloc=KernelAllocWrapper(i,%val(PtrVector))
integer(4) function KernelDeAlloc(i,PtrVector)
implicit none
!DEC$ ATTRIBUTES C,ALIAS:'_KernelDeAlloc' ::KernelDeAlloc
!DEC$ ATTRIBUTES DLLEXPORT::KernelDeAlloc
integer(4):: i
intege r(int_ptr_kind()) PtrVector
KernelDeAlloc=KernelDeAllocWrapper(i,%val(PtrVector))
So, I used standard F90 pointers and assumed-shape arrays in the interface and let the C code to take care of descriptors (their storage and dereferencing lpAddress).
Too bad that C is a requirement. C++ code based on the wrapper class I mention would be as simple as:
#include "VFArray.h"
VFArrayA.allocate(10);
for (i=0; i10; i++) A = i;
KernelCall(A);
for (i=0; i10; i++) printf("%10.6f", A);
A.deallocate();
If you're using Intel Fortran, note that it has an additional member in CVF_1D_DESCRIPTOR, so take care about it in C caller.
HTH
Jugoslav
Message Edited by JugoslavDujic on 10-12-2005 11:56 AM
Message Edited by JugoslavDujic on 10-12-2005 11:57 AM
A simple linked lists of array descriptors would work
Code:
module myModule type Real8Array1 real(8), pointer :: array(:) end type Real8Array1 type Real8Array2 real(8), pointer :: array(:,:) end type Real8Array2 type F90_allocateNode type(F90_allocateNode), pointer :: next union map type(Real8Array1) :: dim1 end map map type(Real8Array2) :: dim2 end map
! other types and dimensions here end union end type F90_allocateNode type(F90_allocateNode), pointer :: F90_allocateNodeHead contains subroutine myModule_init F90_allocateNodeHead => NULL() end subroutine myModule_init end module myModule
! allocate single dimension of REAL(8)
! returns pointer on success or NULL on failure function F90_Real8allocate1(N) use myModule implicit none integer(int_ptr_kind()) :: F90_Real8allocate1 integer(4) :: N, iStat type(F90_allocateNode), pointer :: Node F90_Real8allocate1 = 0 ! allocate a new node allocate(Node, STAT=iStat) if(iStat .ne. 0) then ! failed, return NULL pointer return endif allocate(Node.dim1.array(N), STAT=iStat) if(iStat .ne. 0) then deallocate(Node) ! failed, return NULL pointer return endif Node.next => F90_allocateNodeHead F90_allocateNodeHead => Node F90_Real8allocate1 = LOC(Node.dim1.array) end function F90_Real8allocate1 subroutine F90_free(P) use myModule implicit none integer(int_ptr_kind()) :: P integer(4) :: iStat type(F90_allocateNode), pointer :: Node, PriorNode PriorNode => NULL() Node => F90_allocateNodeHead do while(associated(Node)) if(LOC(Node.dim1.array) .eq. P) then ! unlink the node if(associated(PriorNode)) then PriorNode.next => Node.next else F90_allocateNodeHead => Node.next endif deallocate(Node.dim1.array) deallocate(Node) return endif PriorNode => Node Node => Node.next end do ! ??? node not found end subroutine F90_free program foo use myModule call myModule_init ! ... end program foo
The above is untested but should give you an idea.
Jim Dempsey
Are these array descriptors something new that came into being with CVF or IVF or with Fortran 90/95/2003? I've seen several mentions of them in this forum, and I was always under the impression that Fortran arrays were just simple lists of the addresses of the array elements. When and why did array descriptors come about?
Mike D.
Fortran arrays used to be simple lists of array elements. However, with f90, an array (pointer, allocatable or array section) apart from starting address can have few additional properties:
- size
- stride for an assumed-shape array (call Foo(X(1:10:2))) or a pointer (P=>X(1:10:2))
- allocated/associated status
The Standard does not specify how these properties should be implemented, but only how they should behave (and passing these properties into routines is probably the most complex issue). Most (all?) F9x compilers use descriptors (aka "dope vectors") to store & pass these data. The programmer should not (nor care) about how they're implemented, unless (s)he deals with mixed-language issues. Alas, they're not compatible accross compilers, (e.g. you can't pass a VF array section to a routine expecting an assumed-shape/pointer argument in an .obj file compiled with g95).
HTH,
Jugoslav
Think of an array in .F90 as a C++ class with private members that are inaccessible (the rank,range, extent, and pointer to memory block)andonepublic member - the base address of the data portion of the array. Fortran allocate filles in the private members as well as the public member. When your C/C++ program calls the FORTRAN proxy allocate routine you return the pointer to the block of memory. It is your responsibility to maintain the inaccessible members of the array if you ever intend to return the memory block. This is a similar analogy to the CSTRING class where your code should delete the class object and not the string to which it points.
Jim Dempsey
Attached is the mixed-language CVF workspace/IVF9 solution I mentioned in this thread. As I said, it's kind of incomplete & untidy, but it demonstrates how it is possible to interface C++ and Fortran arrays, where arrays in C++ are implemented "Fortran" way, i.e. "I wrote Fortran in C++". It also kind of demonstrates inner workings of Fortran compiler -- apart from calling VF routine for testing purposes, the C++ code is pretty much standalone.
It currently works only for 1-D arrays (I probably made a design flaw in implementing rank as a template argument, so it's not so easy to expand it to 2-D as-is).
VFArray template class behaves much like F90 pointers/allocatables, with slight semantic changes:
- A VFArray can be both a "POINTER" and an "ALLOCATABLE", i.e. you can both allocate it and point to a target with it (operator >> is overloaded). It's (hopefully) memory-leak safe (any allocation frees old memory if "owned" by the object).
- Indices are "C-style", i.e. they range from 0 ... size(X)-1. When passed to Fortran, they behave as 1 ... size(X)
- If 2-D case (commented out) worked, it would use row-major order (seen from Fortran callee as column-major).
I'll make it available on www.xeffort.com once I complete it.
Jugoslav
Do you wish to perform all of the memory allocations in the F90 code?
If so, I would suggest you consider writing your own newhandler verses using templates like jugoslav suggests. The C++ code permits user code to replace what is called by new and delete. This little routine would then call the fortran code for the allocation and deallocation. If your code is C as you state then consider using the cpp to replace the malloc, alloc, alloca, ... with #defines.
Are you using C or C++?
Jim Dempsey
Jim Dempsey
integer(4) function KernelAllocWrapper(i,PtrVector) implicit none integer(4) :: i integer(int_ptr_kind()) PtrVector real(8), pointer :: F90_PointerVector(:) allocate(F90_PointerVector(1:i)) PtrVector=%LOC(F90_PointerVector) KernelAllocWrapper=0 endfunction KernelAllocWrapper
contains more data then simply an integer(4) address.
is either created on the stack or in global memory with a mangled name which usualy contains the function name with other stuff. This may create reentrancy issues.
we would like to allocate and deallocate memory in C/C++ und use the arrays / structures
allocated and populated in C7C++ on the Fortran side where FORTRAn should be able to obtain
a "pointer" to the data by calling a C function and operate on the data.
Are your the mixed-language allocate in C use in Fortran (with getting pointer in FORTRAN ...)
examples still available somewhere for download?
Thanks for all your insight
Wolfgang
