Module variable is shown to be undefined in the "watch" window
dimdol10
I'm using the intel parallel studio (XE2018 update 1 cluster edition).
I found that a variable globally defined in a module is shown as undefined variable in the "watch" window, as depicted below, even though the module is declared as "USE" in the subroutine.
I attached a sample code illustrating this issue.
If I use this variable in the subroutine, then the "watch" window shows the variable properly. But, if it is not used explicitly, it is declared as undefined variable.
In my opinion, even though the variable ("m_tot" in the attached code) is not explicitly used in the subroutine, it needs to be a defined variable since the subroutine use the module where the variable is defined.
I hope to get some comments on this.
Below is the sample code.
      MODULE test_module
      DOUBLE PRECISION M_TOT
      END MODULE
      PROGRAM Module_test
      USE test_module
      INTEGER a,b,c
      a=10
      b=11
      c = a + b
      continue
      END
andrew_4619
The debugger only shows module variables that are actually used in a subprogram you can explicitly watch modulename::varname if you want to. IMO to show all module vars would in many cases be too much information.
