Seems that v17 was not the most lucky of all releases. In our code, link, we now see several of our unit and functional tests producing double free or corruption errors or simply just hang. Note that you need OCaml to compile the code, but otherwise it is just ./configure, make, make check. Til roughly a year ago our code was regularly checked for regressions by a person of the Intel support, but with the stop the code doesn't work any more now. Maybe at some point I might provide a smaller test case, but I'm not so highly motivated to do so.
链接已复制
I'm sorry to learn there are new issues. I think the answer is probably "Yes", but to confirm, is the double free/corruption error occurring with 17.0 update 2?
I believe I know who the Intel person was so I will inquire whether that testing was continued by someone else.
Please let us know if you learn anything further about this issue.
Here is the reproducer (you need just an empty file sf_data_14.ref). With gfortran 4.8/4.9/5/6/7, ifort 16, PGF 17, nagfor 6 it works,
for ifort v17 it just hangs.
module unit_tests
implicit none
private
public :: unit_test
public :: test
abstract interface
subroutine unit_test (u)
integer, intent(in) :: u
end subroutine unit_test
end interface
contains
subroutine test (test_proc, u_log)
procedure(unit_test) :: test_proc
integer, intent(in) :: u_log
integer :: u_test, u_ref, u_err
logical :: exist
character(256) :: buffer1, buffer2
integer :: iostat1, iostat2
logical :: success
write (*, "(A)", advance="no") "Running test: "
write (u_log, "(A)") "Test: "
u_test = 12
open (u_test, status="scratch", action="readwrite")
call test_proc (u_test)
rewind (u_test)
inquire (file="sf_base_14.ref", exist=exist)
if (exist) then
u_ref = 13
open (u_ref, file="sf_base_14.ref", status="old", action="read")
COMPARE_FILES: do
read (u_test, "(A)", iostat=iostat1) buffer1
read (u_ref, "(A)", iostat=iostat2) buffer2
if (iostat1 /= iostat2) then
success = .false.
exit COMPARE_FILES
else if (iostat1 < 0) then
success = .true.
exit COMPARE_FILES
else if (buffer1 /= buffer2) then
success = .false.
exit COMPARE_FILES
end if
end do COMPARE_FILES
close (u_ref)
else
write (*, "(A)", advance="no") " ... no reference output available"
write (u_log, "(A)") " No reference output available."
success = .false.
end if
write (*, "(A)") " ... success."
write (u_log, "(A)") " Success."
close (u_test)
end subroutine test
end module unit_tests
module sf_base
implicit none
private
public :: sf_data_t
public :: sf_config_t
public :: sf_int_t
public :: sf_chain_t
public :: sf_chain_instance_t
type, abstract :: sf_data_t
contains
procedure (sf_data_get_int), deferred :: get_n_par
procedure (sf_data_allocate_sf_int), deferred :: allocate_sf_int
end type sf_data_t
type :: sf_config_t
integer, dimension(:), allocatable :: i
class(sf_data_t), allocatable :: data
contains
procedure :: init => sf_config_init
end type sf_config_t
type, abstract :: sf_int_t
real, dimension(:), allocatable :: mi2
real, dimension(:), allocatable :: mr2
real, dimension(:), allocatable :: mo2
integer, dimension(:), allocatable :: beam_index
integer, dimension(:), allocatable :: par_index
contains
procedure :: base_init => sf_int_base_init
procedure (sf_int_init), deferred :: init
end type sf_int_t
type :: sf_instance_t
class(sf_int_t), allocatable :: int
real, dimension(:,:), allocatable :: r
real, dimension(:), allocatable :: f
logical, dimension(:), allocatable :: m
real, dimension(:), allocatable :: x
end type sf_instance_t
type :: sf_chain_t
integer :: n_in = 0
integer :: n_strfun = 0
integer :: n_par = 0
integer :: n_bound = 0
type(sf_instance_t), dimension(:), allocatable :: sf
contains
procedure :: init => sf_chain_init
procedure :: set_strfun => sf_chain_set_strfun
procedure :: get_n_par => sf_chain_get_n_par
end type sf_chain_t
type :: sf_chain_instance_t
type(sf_chain_t), pointer :: config => null ()
integer :: selected_channel = 0
real, dimension(:,:), allocatable :: p, pb
logical, dimension(:), allocatable :: bound
contains
procedure :: init => sf_chain_instance_init
end type sf_chain_instance_t
abstract interface
function sf_data_get_int (data) result (n)
import
class(sf_data_t), intent(in) :: data
integer :: n
end function sf_data_get_int
end interface
abstract interface
subroutine sf_data_allocate_sf_int (data, sf_int)
import
class(sf_int_t), intent(inout), allocatable :: sf_int
end subroutine sf_data_allocate_sf_int
end interface
abstract interface
subroutine sf_int_init (sf_int, data)
import
class(sf_int_t), intent(out) :: sf_int
class(sf_data_t), intent(in), target :: data
end subroutine sf_int_init
end interface
contains
subroutine sf_config_init (sf_config, i_beam, sf_data)
class(sf_config_t), intent(out) :: sf_config
integer, dimension(:), intent(in) :: i_beam
class(sf_data_t), intent(in) :: sf_data
allocate (sf_config%i (size (i_beam)), source = i_beam)
allocate (sf_config%data, source = sf_data)
end subroutine sf_config_init
subroutine sf_int_base_init &
(sf_int, mi2, mr2, mo2)
real, dimension(:), intent(in) :: mi2, mr2, mo2
allocate (sf_int%mi2 (size (mi2)))
sf_int%mi2 = mi2
allocate (sf_int%mr2 (size (mr2)))
sf_int%mr2 = mr2
allocate (sf_int%mo2 (size (mo2)))
sf_int%mo2 = mo2
end subroutine sf_int_base_init
subroutine sf_chain_init (sf_chain, sf_config)
class(sf_chain_t), intent(out) :: sf_chain
type(sf_config_t), dimension(:), intent(in), optional, target :: sf_config
integer :: i
if (present (sf_config)) then
sf_chain%n_strfun = size (sf_config)
allocate (sf_chain%sf (sf_chain%n_strfun))
do i = 1, sf_chain%n_strfun
call sf_chain%set_strfun (i, sf_config(i)%i, sf_config(i)%data)
end do
end if
end subroutine sf_chain_init
subroutine sf_chain_set_strfun (sf_chain, i, beam_index, data)
class(sf_chain_t), intent(inout) :: sf_chain
integer, intent(in) :: i
integer, dimension(:), intent(in) :: beam_index
integer :: n_par, j
n_par = data%get_n_par ()
call data%allocate_sf_int (sf_chain%sf(i)%int)
associate (sf_int => sf_chain%sf(i)%int)
call sf_int%init (data)
sf_chain%n_par = sf_chain%n_par + n_par
end associate
end subroutine sf_chain_set_strfun
function sf_chain_get_n_par (sf_chain) result (n)
class(sf_chain_t), intent(in) :: sf_chain
integer :: n
n = sf_chain%n_par
end function sf_chain_get_n_par
subroutine sf_chain_instance_init (chain, config, n_channel)
class(sf_chain_instance_t), intent(out), target :: chain
type(sf_chain_t), intent(in), target :: config
integer, intent(in) :: n_channel
integer :: i, j
integer :: n_par_tot, n_par, n_strfun
chain%config => config
n_strfun = config%n_strfun
n_par_tot = 0
if (n_strfun /= 0) then
allocate (chain%sf (n_strfun))
do i = 1, n_strfun
associate (sf => chain%sf(i))
allocate (sf%int, source=config%sf(i)%int)
n_par = size (sf%int%par_index)
allocate (sf%m (n_channel)); sf%m = .false.
allocate (sf%x (n_par)); sf%x = 0
n_par_tot = n_par_tot + n_par
end associate
end do
allocate (chain%p (n_par_tot, n_channel)); chain%p = 0
allocate (chain%pb(n_par_tot, n_channel)); chain%pb= 0
end if
allocate (chain%bound (n_par_tot), source = .true.)
end subroutine sf_chain_instance_init
end module sf_base
module sf_base_uti
use sf_base
implicit none
private
public :: sf_base_14
type, extends (sf_data_t) :: sf_test_data_t
integer :: mode = 0
real :: m = 0
contains
procedure :: init => sf_test_data_init
procedure :: get_n_par => sf_test_data_get_n_par
procedure :: allocate_sf_int => sf_test_data_allocate_sf_int
end type sf_test_data_t
type, extends (sf_int_t) :: sf_test_t
type(sf_test_data_t), pointer :: data => null ()
real :: x = 0
contains
procedure :: init => sf_test_init
end type sf_test_t
type, extends (sf_data_t) :: sf_test_generator_data_t
real :: m = 0
contains
procedure :: init => sf_test_generator_data_init
procedure :: get_n_par => sf_test_generator_data_get_n_par
procedure :: allocate_sf_int => &
sf_test_generator_data_allocate_sf_int
end type sf_test_generator_data_t
type, extends (sf_int_t) :: sf_test_generator_t
type(sf_test_generator_data_t), pointer :: data => null ()
contains
procedure :: init => sf_test_generator_init
end type sf_test_generator_t
contains
subroutine sf_base_14 (u)
class(sf_data_t), allocatable, target :: data_strfun
class(sf_data_t), allocatable, target :: data_generator
type(sf_config_t), dimension(:), allocatable, target :: sf_config
real, dimension(:), allocatable :: p_in
type(sf_chain_t), target :: sf_chain
type(sf_chain_instance_t), target :: sf_chain_instance
allocate (sf_test_data_t :: data_strfun)
select type (data_strfun)
type is (sf_test_data_t)
call data_strfun%init ()
end select
allocate (sf_test_generator_data_t :: data_generator)
select type (data_generator)
type is (sf_test_generator_data_t)
call data_generator%init ()
end select
allocate (sf_config (2))
call sf_config(1)%init ([1,2], data_generator)
call sf_config(2)%init ([2], data_strfun)
call sf_chain%init (sf_config)
call sf_chain_instance%init (sf_chain, n_channel = 1)
end subroutine sf_base_14
subroutine sf_test_data_init (data, mode)
class(sf_test_data_t), intent(out) :: data
integer, intent(in), optional :: mode
if (present (mode)) data%mode = mode
end subroutine sf_test_data_init
function sf_test_data_get_n_par (data) result (n)
class(sf_test_data_t), intent(in) :: data
integer :: n
n = 1
end function sf_test_data_get_n_par
subroutine sf_test_data_allocate_sf_int (data, sf_int)
if (allocated (sf_int)) deallocate (sf_int)
allocate (sf_test_t :: sf_int)
end subroutine sf_test_data_allocate_sf_int
subroutine sf_test_init (sf_int, data)
class(sf_test_t), intent(out) :: sf_int
select type (data)
call sf_int%base_init (&
[data%m**2], [0.], [data%m**2])
end select
end subroutine sf_test_init
subroutine sf_test_generator_data_init (data)
class(sf_test_generator_data_t), intent(out) :: data
end subroutine sf_test_generator_data_init
function sf_test_generator_data_get_n_par (data) result (n)
class(sf_test_generator_data_t), intent(in) :: data
integer :: n
n = 2
end function sf_test_generator_data_get_n_par
subroutine sf_test_generator_data_allocate_sf_int (data, sf_int)
allocate (sf_test_generator_t :: sf_int)
end subroutine sf_test_generator_data_allocate_sf_int
subroutine sf_test_generator_init (sf_int, data)
class(sf_test_generator_t), intent(out) :: sf_int
select type (data)
call sf_int%base_init ( &
[data%m**2, data%m**2], &
[real :: ], &
[data%m**2, data%m**2])
sf_int%data => data
end select
end subroutine sf_test_generator_init
end module sf_base_uti
program main_ut
use unit_tests
use sf_base_uti, only: sf_base_14
implicit none
call test (sf_base_14, 11)
end program main_ut
And, there is more behind the corner. By using the test case on the very top (our full code), I get this:
You do have the reproducer for this as well, where you don't even need OCaml. Just download the link,
http://whizard.hepforge.org/versions/unofficial/whizard-2.4.1_alpha-20170131.tar.gz
do ./configure, make, make install. Then go to the build dir, tests/functional_tests, do 'make testproc_1.run` and
then ./testproc_1.run produces the problem below (shall a file another official report here?)
| Reading model file '/home/reuter/local/packages/whizard/trunk/share/models/SM_hadrons.mdl'
| Reading commands from file 'testproc_1.sin'
| Reading model file '/home/reuter/local/packages/whizard/trunk/share/models/Test.mdl'
| Loading model auxiliary library '/home/reuter/local/packages/whizard/trunk/_build_ifort17/src/models/external.Test.so.0'
| Switching to model 'Test'
?logging => true
?openmp_logging = false
?vis_history = false
?integration_timer = false
$method = "unit_test"
process_num_id = 42
| Process library 'default_lib': recorded process 'testproc_1_p1' (42)
seed = 0
| Process library 'default_lib': compiling ...
| Process library 'default_lib': ... success.
$phs_method = "single"
$integration_method = "midpoint"
sqrts = 1.000000000000E+03
| RNG: Initializing TAO random-number generator
| RNG: Setting seed for random-number generator to 0
| Initializing integration for process testproc_1_p1:
| Beam structure: [any particles]
| Beam data (collision):
| s (mass = 1.2500000E+02 GeV)
| sqrts = 1.000000000000E+03 GeV
| Process [scattering]: 'testproc_1_p1'
| ID (num) = 42
| Library name = 'default_lib'
| Process index = 1
| Process components:
| 1: 'testproc_1_p1_i1': s, s => s, s [unit_test]
| Phase space: 1 channels, 2 dimensions
| Phase space: single-particle
Warning: No cuts have been defined.
*** Error in `/home/reuter/local/packages/whizard/trunk/_inst_ifort17/bin/whizard': double free or corruption (fasttop): 0x0000000000daa090 ***
Program received signal SIGABRT, Aborted.
0x00007fffef18dc37 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt
#0 0x00007fffef18dc37 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x00007fffef191028 in __GI_abort () at abort.c:89
#2 0x00007fffef1ca2a4 in __libc_message (do_abort=do_abort@entry=1, fmt=fmt@entry=0x7fffef2d86b0 "*** Error in `%s': %s: 0x%s ***\n") at ../sysdeps/posix/libc_fatal.c:175
#3 0x00007fffef1d655e in malloc_printerr (ptr=<optimized out>, str=0x7fffef2d8878 "double free or corruption (fasttop)", action=1) at malloc.c:4996
#4 _int_free (av=<optimized out>, p=<optimized out>, have_lock=0) at malloc.c:3840
#5 0x000000000045e818 in for_dealloc_allocatable ()
#6 0x00007ffff48fa7bd in instances::term_instance_init (term=0xdb0f60, process=..., i_term=1, real_finite=.FALSE.) at instances.f90:509
#7 0x00007ffff49095e8 in instances::term_instance_init_from_process (term_instance=0xdb0f60, process=..., i=1, pcm_instance=..., sf_chain=...) at instances.f90:579
#8 0x00007ffff4954cba in instances::process_instance_init (instance=0xdb0320, process=...) at instances.f90:1584
#9 0x00007ffff3db95ce in integrations::integration_integrate (intg=0x7fffffff9d00, local=..., eff_reset=<error reading variable: Cannot access memory at address 0x0>)
at integrations.f90:689
#10 0x00007ffff3dd00db in integrations::integrate_process (process_id=..., local=..., global=..., local_stack=<error reading variable: Cannot access memory at address 0x0>,
init_only=<error reading variable: Cannot access memory at address 0x0>, eff_reset=<error reading variable: Cannot access memory at address 0x0>) at integrations.f90:880
#11 0x00007ffff3f16df8 in commands::cmd_integrate_execute (cmd=0xd68f60, global=...) at commands.f90:3124
#12 0x00007ffff3fe72d3 in commands::command_list_execute (cmd_list=0x7fffffffa7b0, global=...) at commands.f90:5862
#13 0x00007ffff4015121 in whizard::whizard_process_stream (whizard=0x789dc0, stream=..., lexer=..., quit=.FALSE., quit_code=0) at whizard.f90:348
#14 0x00007ffff4010644 in whizard::whizard_process_file (whizard=0x789dc0, file=..., quit=.FALSE., quit_code=0) at whizard.f90:323
#15 0x00007ffff7bcaba9 in main () at main.f90:415
#16 0x000000000040a71e in main ()
I submiited this a smaller reproducer (still couple of files though) with the report ticket #02641438.
I sincerely hope that this together with the other issue (which might [or might not] have the same root case), issue #2641369, will be fixed very soon. For the moment, we disabled usage with ifort 17 for our code. This is really annoying as ifort 16 (in all subversions) was after years the first ifort version that could compile and run our code as intended.
