- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I am trying to install IFC 2013 update 6 on my Ubuntu 16 64 bit version.
I need to get the 32 bit libraries installed. I thought that I had them all install, but the IFC installer is still complaining.
32-bit libraries not found on this system.
This product release requires the presence of 32-bit compatibility libraries
when running on Intel(R) 64 architecture systems. One or more of these libraries
could not be found:
libstdc++ (including libstdc++6)
glibc
libgcc
Without these libraries, the compiler and the debugger will not function
properly. Please refer to Release Notes for more information.
Please help.
- Etiquetas:
- Intel® Fortran Compiler
Enlace copiado
- « Anterior
- 1
- 2
- Siguiente »
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
For Unubtu 16, perhaps these instructions will help:
https://blog.teststation.org/ubuntu/2016/05/12/installing-32-bit-software-on-ubuntu-16.04/
Thank you,
Eugene
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
What the Intel installer is asking you to do is to install the GCC/GLIBC 32-bit components first.
In other words, on your machine install the necessary packages (typically, their names contain '32', such as 'compat32') to be able to compile a 32-bit a.out from, say, a "Hello Fortran World" program written in C. Try gcc -m32 <some_file>.c and, if that works, go on to the Intel installer.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
https://blog.teststation.org/ubuntu/2016/05/12/installing-32-bit-softwar...
Thank you,
Eugene
I have already done that. IFC installer still tells me to install the 32bit libraries
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
As previous poster suggested, please create a simple C program and try to compile it for 32 bits. This will show, whether 32 bit libraries installed correctly. For example, here's hello.c:
#include <stdio.h>
int main()
printf("Hello world!\n") ;
return 0 ;
Then run "gcc -m32 -o hello32 hello.c" and ensure that "hello32" runs correctly.
At the moment, I have access to Ubuntu 14 system. Here's the output of ldd command on 32 bit and 64 bit executables on that system:
$ ldd hello32linux-gate.so.1 => (0xf774c000)libc.so.6 => /lib32/libc.so.6 (0xf7590000)/lib/ld-linux.so.2 (0x56576000)
$ ldd hello64linux-vdso.so.1 => (0x00007ffe7d887000)libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5baadc9000)/lib64/ld-linux-x86-64.so.2 (0x000055eb2a6ea000
Are you able to compile and execute hello32?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
#include <stdio.h> int main() { printf("Hello world!\n") ; return 0 ; }Then run "gcc -m32 -o hello32 hello.c" and ensure that "hello32" runs correctly.
$ ldd hello32
$ ldd hello64
Here is what I got. I was able to compile Hello32
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I still have not found a fix.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Ok, seems like your 32 bit C libraries are fine. The installation program also asked for 32 bit libstd++. Let's now try the same test for C++:
#include <iostream>
int main()
std::cout << "Hello C++ world!\n" ;
return 0 ;
$ g++ -m32 -o hellopp32 hello.cpp
$ ldd hellopp32linux-gate.so.1 => (0xf7743000)libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xf75a0000)libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf73ea000)libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf7395000)/lib/ld-linux.so.2 (0xf7744000)libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf7378000)
Does this also work for you?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
#include <iostream> int main() { std::cout << "Hello C++ world!\n" ; return 0 ; }$ g++ -m32 -o hellopp32 hello.cpp
$ ldd hellopp32
This is what I get
allisbs@issallisbs:~$ g++ -m32 -o hello32 hello32.cpp
In file included from hello32.cpp:1:0:
/usr/include/c++/5/iostream:38:28: fatal error: bits/c++config.h: No such file or directory
compilation terminated.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Something is indeed wrong with your gcc/g++ compiler installation. I did a quick research into this error, and it's possible that you are missing "g++-multilib" package.
Here are some links that may help you to resolve C++ compilation issue:
(The links are about cross compiling 64 bit on 32 bit, which is opposite of what you are trying to do, but I think the solution would be similar.)
Once you resolve this and hello.cpp compiles fine for 32 bit, the IFC installer *should* stop complaining.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
ok I installed g++multilib
Then tried to create hellopp32. It got it created and this is what i got when I ran ldd hellopp32
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I still need help on this.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Sorry, I somehow stopped getting notifications for this thread.
Ok, so you were able to create hellocpp32. Does hellocpp32 run? Did you try to run the installer again?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I have tried the installer again and same problem, it complains that the 32 bit libraries are not installed.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
> IFC 2013 update 6
Would it be possible for you to try a later compiler? It's possible that 2013 release checks for a specific 32 bit library version (or for 32 bit library that is no longer used).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
yes hellocpp32 runs
I have to use the 2013 with our software because we have not tested newer compilers with our software yet. If I install the 32bit Ubuntu, the intel 2013 32bit version installs just fine.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hmm, that's interesting. Some suggestions:
(1) On your 32 bit Ubuntu, compile a 32 bit Fortran program, then run "ldd" on that program's binary on 32 bit Ubuntu and provide the output. Maybe this will tell us, which other 32 bit library is missing.
(2) On your 32 bit Ubuntu, compile a 32 bit Fortran program, then copy this 32 bit program to your 64 bit Ubuntu and try to run it there. Please run "ldd" on 64 bit Ubuntu on this program and provide the output.
(3) If you just *try* to install latest compiler on 64 bit Ubuntu, does the installation fail with the same error, or does it proceed?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Are you sure you need to install these?
The error message the Install_GUI gives is intimidating, but if you just ignore it, the installation proceeds okay, I think.
The resulting installation can't cross-build from Intel 64 to a 32 bit system, but many users don't need to do that.
Also the resulting installation has problems with the Amplifier and Advisor GUI's - I am still investigating this area
/Bevin - emtpgeek consulting llc, intel retiree
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
could not be found:
glibc
libgcc
I believe to remember similar error messages when installing Intel Parallel Studio versions 18 an 19 (beta) on Ubuntu. The simple solution was to install libc6-dev-i386. With Ubuntu 14.04 LTS one could easily install it using the Ubuntu Software Center. With Ubuntu 16.04 LTS I did use Synaptic (which can easily be installed through the Ubuntu Software Center) to install it.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
- « Anterior
- 1
- 2
- Siguiente »
