Need Intel Fortran 2017
SaeedM
Hello
Due to some compatibility issue, I need to install the older version of Intel Parallel studio XE 2017 Update 5. Does any body know how to install that specific version?
Best regards
SaeedM
Steve_Lionel
Do you have a support contract? If so, you can request it by opening a support ticket. If not, then no. Why do you need that specific old version? If it's for "compatibility" with some third-party product, you can use the current 2021 version, at most making small changes in the paths of scripts and libraries.
Steve_Lionel
SaeedM
Hello Steve
This is what I get:
error #7881: This module file was generated for a different platform or by an incompatible compiler or compiler release. It cannot be read. [IVPAG_INT]
It is a third party library that apparently not compatible.
Steve_Lionel
That's an IMSL module. My guess is that you are mixing 32-bit and 64-bit - you'll get that error if you do. Make sure that you have specified the correct IMSL module path for the platform you are using. Intel compilers can read old .mod files.
SaeedM
Hello Steve, Thanks for the information, you were right. I fixed the issue by changing to 64 bit.
