Nested Select Type
Dharma
I seem to get a wrong result on using nested select type. Can you tell me if this code is incorrect or if it is a problem with the compiler (ifort version 12.1.0).
[fortran]module comparator
  implicit none
contains
  function compareLess(A,B) result(comp)
    class(*),pointer, intent(in) :: A
    class(*),pointer, intent(in) :: B
    logical :: comp
    comp=.false.
    select type(C=>A)
      ! Check if Type of A is integer
      type is(integer)
      select type(D=>B)
        type is(integer)
        comp = C.lt.D
      end select
      print*,'Error :: A is type int, B is not type int'
      stop
      ! Check if Type of A is real
      type is(real)
      print*,'Type of A is real',C
      select type(D=>B)
        type is(real)
        comp = C.lt.D
      end select
      print*,'Error :: A is type real, B is not type real'
      stop
      ! Check if Type of A is character
      type is(character(len=*))
      select type(D=>B)
        comp = C.lt.D
      end select
      print*,'Error :: A is type character, B is not type character'
      stop
    end select
  end function compareLess
end module comparator
program TestComp
  use comparator
  class(*), pointer :: A
  class(*), pointer :: B
  ! enable to test integer
  integer, pointer :: C
  integer, pointer :: D
  ! enable to test reals
  !real, pointer :: C
  !real, pointer :: D
  logical :: comp
  allocate(C,D)
  !call random_number(C)
  !call random_number(D)
  C=5
  D=8
  A => C
  B => D
  ! Method 1
  ! Code compiles, and runs but the result is,
  ! Error :: A is type int, B is not type int
  comp = compareLess(A,B)
  print*,'A is',C,'and B is',D,'A is less than B :',comp
 ! Method 2
 ! Code compiles, and throws error,
 ! severe (40): recursive I/O operation, unit -1, file unknown
 ! This may be understanable, I tried method 2 first before i tried method 1.
 ! How does on deal with a situation like this, where one wants to print the result
 ! of compare but also let the compare print an error messge in case of error in compare.
 ! Test for sucess of compare and then print?
 ! Enable to test method 2
 !print*,'A is',C,'and B is',D,'A is less than B :',compareLess(A,B)
end program TestComp[/fortran]
Anonymous66
Valued Contributor I
You need to add a return after line 14, line 22, and line 31. Because there is no return of break statement, the program continues and hits the error code after it does the comparison.
Dharma
Thanks. I should have paid more attention :)
