29654 Discussions
-static-intel causes OpenMP data races ?
Alexis_R_
Using:
ifort 12.1.0
intel inspector XE 2011 Update 7 (build 189290)
On: RHEL 5, 64bit
The following file test.f90:
[fortran]module mod
 contains
	!>	\brief	Test whether OpenMP is available
	LOGICAL FUNCTION OPENMP_IS_AVAILABLE()
		USE OMP_LIB
		IMPLICIT NONE
		! Arguments
		! Private variables
		! Start work
		!$OMP	PARALLEL    &
		!$OMP          SHARED(OPENMP_IS_AVAILABLE)
		!$OMP	SINGLE
		IF (OMP_GET_ACTIVE_LEVEL() .GT. 0) THEN
			OPENMP_IS_AVAILABLE = .TRUE.
		ELSE
			OPENMP_IS_AVAILABLE = .FALSE.
		ENDIF
		!$OMP	END SINGLE
		!$OMP	END PARALLEL
	END FUNCTION OPENMP_IS_AVAILABLE
end module mod
program omptest
  use mod
  if (openmp_is_available()) then
   write(*,'(a)') 'openmp is available'
  endif
end program omptest[/fortran]
Compiled like this:
[bash]ifort -openmp -static-intel test.f90[/bash]
And then thread-checked with Inspector (analysis type "Locate Deadlocks and Data Races", stack frame depth 24, scope "Extremely thorough") gives a number of Data races:
[bash]ID  Problem Sources Modules State
P1  Data race [Unknown] a.out Not fixed
P2  Data race [Unknown] a.out Not fixed
P3  Data race [Unknown] a.out Not fixed
P4  Data race [Unknown] a.out Not fixed
P5  Data race [Unknown] a.out New
P6  Data race [Unknown] a.out Not fixed
P7  Data race [Unknown] a.out Not fixed
P8  Data race [Unknown] a.out Not fixed
P9  Data race [Unknown] a.out Not fixed
P10  Data race [Unknown] a.out Not fixed
P11  Data race [Unknown] a.out Not fixed
P12  Data race [Unknown] a.out Not fixed
P13  Data race [Unknown] a.out Not fixed
P14  Data race [Unknown] a.out Not fixed
P15  Data race [Unknown] a.out Not fixed
P16  Data race [Unknown] a.out Not fixed
[/bash]
Removing the -static-intel option from the compile line solves the problem, but it took me a while to figure out what was going on, so perhaps this is worth fixing? Or is this behaviour expected?
pbkenned1
Thanks for the report. There are two issues here.
First, there's an ifort driver bug because -static-intel is supposed to link everything statically, except for the OpenMP runtime library. But that's not happening:
> ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
> ifort -openmp -static-intel U87100.f90 -o U87100-static-intel.x
> ldd U87100-static-intel.x
libm.so.6 => /lib64/libm.so.6 (0x00002aaaaabc7000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00002aaaaad1c000)
libc.so.6 => /lib64/libc.so.6 (0x00002aaaaae33000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaab065000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaab172000)
/lib64/ld-linux-x86-64.so.2 (0x00002aaaaaaab000)
Second, Inspector is known to report false positives when linking the static OpenMP runtime. I suspect that's why when you remove -static-intel and link dynamically, all is well. So really, the secondissue is just a side-effect of the driver/linking bug.
I'll file a bug report for the first issue. You know how to deal with the second issue.
Patrick Kennedy
Intel Developer Support
pbkenned1
The tracking number for this defect is DPD200174693. I'll keep this thread updated with the progress to repair.
Patrick
