29632 Discussions
Nested defined assignment not called with parameterized derived type
WileyOne
Compiler: ifx (IFX) 2025.2.0
OS: Rocky Linux 8.10 (Green Obsidian)
I've found a bug at the intersection of parameterized derived types and defined assignment, specifically when nested 3 classes deep. In the following code, the print statement should display, but it does not.
module Classes_Header
    implicit none
    type :: class1
        integer :: ii
        contains
        generic, public :: assignment(=) => copy
        procedure, private :: copy
    end type
    type :: class2
        type(class1) :: myClass1
    end type
    type :: class3(n)
        integer, len :: n
        type(class2) :: myClass2
    end type
    contains
    subroutine copy(lhs,rhs)
        class(class1), intent(out) :: lhs
        class(class1), intent(in)  :: rhs
        lhs%ii = 7
        print *, 'copy was called - worked as expected'
    end subroutine
    function constructor() result(this)
        type(class3(4)) :: this
        this%myClass2%myClass1%ii = 42
    end function
end module
program main
    use Classes_Header
    implicit none
    type(class3(:)), allocatable :: myClass3
    myClass3 = constructor()
end program
Note that if class3 is not a parameterized derived type, the defined assignment is called as expected. This is true even if class3 remains an allocatable in the program main.
Igor_V_Intel
The fix is implemented and will be available in the next major compiler release.
WileyOne
Note the similarities and differences between this and another issue I just updated. In both bugs, the defined assignment is not called. Here, the problem comes from the parameterized derived type, while the other issue is a nested class structure containing an `allocatable` class.
Ron_Green
Thank you for sending this to us. The bug ID is CMPLRLLVM-68773
WileyOne
Three other cases to add here. They are subtle differences from my original post, but I wanted to make sure these edge cases were caught. In short, the defined assignment is neither called when class3 is a class-allocatable nor when it extends from an abstract class nor when it's a type with the same parameter; see the attached files for specifics. I appended "TypeAllocatable_OriginalPost" onto the name of the file above for clarity, but it is the same otherwise.
@Ron_Green, should I make separate issues for these bugs or leave them as part of this one?
Igor_V_Intel
WileyOne
WileyOne
I have confirmed that this is working correctly with the latest compiler version (2026.0.0). Thank you, Intel team!
