29275 Discussions
New license obtained, reinstall the compiler?
CO_Traut
hi, there
Last month I downloaded the trial version ifort on Mac, and it expired a couple days ago.
Now I bought a formal license... I am trying to find the license file to insert my new # so that I can avoid the reinstallation...but did not find that file... look forward to your instruction.
best,
Kevin_D_Intel
First register the new S/N # at the Intel Registration Center (here) after which a new license file (.lic) will be emailed to you. Drop that new .lic file onto the system into: /Users/Shared/Library/Application Support/Intel/Licenses and the compilershould pick it up.
Kevin_D_Intel
TimP
If you lost track of the license file, you should be able to get another copy e-mailed from https://registrationcenter.intel.com Then you can simply copy it into the licenses directory. While you're about it, you could consider looking for a compiler update on registrationcenter.
Re-installing the compiler or an update, if you have internet access, by entering the license key, should create a new license file.
Shamla_P_Intel
Greetings,
I have resend you the license file. Here i the link to an article which explains how you can resend the license file to yourself.
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-top-getting-started-issues/#6
In case you forgot your login id , please let us know and I will send you a private message with this information.
Thank You
Shamla
