No .exe file output
royxu
I tried to find .exe file after successfully building my project but not found.
Here is the message after building project:
1>------ Build started: Project: version2ewoc, Configuration: Debug Win32 ------
1>There is no build command line to execute.
1>
1>Performing Makefile project actions
1>Build log was saved at "file://c:Documents and SettingsRoyVisual Fortranversion2ewocDebugBuildLog.htm"
1>version2ewoc - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
I checked Project->Properties->Configuration Properties->General and found the output directory is .Debug. I should find .exe file in that directory. Do I miss something here?
Thanks for any input!
Roy
It sounds as if this is not a Fortran project. Is there a blue box with a white F next to the Fortran project name? Did you convert this from a CVF project? If so, you seem to have missed the second step which is to right click on the project and select "Extract Compaq Visual Fortran Project Items".
