29359 Discussions
No values for >1 dimensional arrays when debugging in Visual Studio 2019
RutgerKok
Hi all,
I'm trying to debug an Abaqus subroutine using Visual Studio, but the locals window won't show any values for arrays that have more than 1-dimension. In other words, I can see the values of scalars and vectors, but not matrices ("C" for example, is a 6x6 matrix). The locals window will say "An unspecified error has occurred", and if I hit refresh it will state that "identifier 'variableName' is undefined".  As you can see in the image, there is no type given for the >1 dimensional arrays.
Note the arrays seem to contain the correct values, they just aren't showing up in the locals window. I also tried to determine the values of elements in the arrays by specifying array slices in a watch window, but that didn't work either.
(full screenshot in attachments)
I am using Abaqus 2019 with the oneAPI base+HPC toolkit and Visual Studio Community 2019. I have no issues with compilation. The compiler options are in the document attached.
Thanks for your help!
Rutger
Steve_Lionel
You don't have the Fortran debugging support working - it is assuming C. I suggest an uninstall and reinstall of the Base toolkit, making sure that "Intel Distribution for GDB" is enabled.
Steve_Lionel
RutgerKok
Hi Steve,  I re-installed the base toolkit and it now works perfectly.
Last time I installed the base toolkit I only installed the "Intel Distribution for GDB" and the packages it required, this time I just installed all the packages just in case.
In any case, all the arrays are showing up properly now.
Thank you!
Steve_Lionel
Glad to hear it, though it should have worked before... I am told that the Fortran debugging support will be moved to the HPC Toolkit in a future update.
