29286 Discussions
Non-pointer real argument passed to a procedure expecting a pointer argument
OP1
New Contributor III
The code below compiles with the latest ifx compiler (2025.1.0), but I am not sure it should. The Intel documentation states:
"A dummy argument that is a pointer can be associated only with an actual argument that is a pointer.link
Shouldn't the call to S1 on line 4 be illegal then, since P is not a pointer?
PROGRAM TEST
IMPLICIT NONE
CALL S1(P)
CALL S2(P)
CONTAINS
    SUBROUTINE P
    IMPLICIT NONE (TYPE, EXTERNAL)
    END SUBROUTINE P
    SUBROUTINE S1(PROC)
    PROCEDURE(P), POINTER, INTENT(IN) :: PROC
    END SUBROUTINE S1
    SUBROUTINE S2(PROC)
    PROCEDURE(P) :: PROC
    END SUBROUTINE S2
END PROGRAM TEST
Steve_Lionel
The documentation has not been updated here to correspond with Fortran 2008, which allows a non-pointer to be passed to an INTENT(IN) pointer:
"If the dummy argument does not have the INTENT (IN), the actual argument shall be a pointer. Otherwise, the actual argument shall be a pointer or a valid target for the dummy pointer in a pointer assignment statement. If the actual argument is not a pointer, the dummy pointer becomes pointer associated with the actual argument." F2008 12.5.2.7 Pointer dummy variables
OP1
New Contributor III
Thanks Steve! @Devorah_H_Intel , this one is for your documentation crew!
Ron_Green
These days it's a crew of one sharing time with the C++ team.
Ron_Green
It looks like we caught this documentation error back in March.  the issue ID is DOC-13286.  I have added your report to the existing bug.  We'll see if we can get this done for the next release.  Thank you for bringing this to our attention.
JohnNichols
Valued Contributor III
No matter how much we try the documentation will remain a century behind reality.    Snoopy's Coding Rule 1313
