Dear all,
when trying to OPEN an existing file with "status=new" from a long absolute path, the open-statement crashes in ifort 16.0.4 (observed with path-length 208 characters or more) or 17.0.4 (216 characters or more), while I did not observe a crash with ifort 15.0.3 and gfortran 4.8.5. Tested on OpenSUSE 42.2 and Ubuntu 14.0.4. The crash can be avoided when either iostat or iomsg is not provided.
program p implicit none integer :: unit, iostat character(500) :: iomsg open( & newunit=unit, & status='new', & file='file', & iostat=iostat, & iomsg=iomsg & ) print *, iomsg close(unit) end program
Expected output:
"cannot overwrite existing file, unit -129, file [...]".
Output on crash:
(I abbreviated the long path with [PATHNAME]:)
*** buffer overflow detected ***: ./a.out terminated ======= Backtrace: ========= /lib64/libc.so.6(+0x721af)[0x2ace8308d1af] /lib64/libc.so.6(__fortify_fail+0x37)[0x2ace83114dc7] /lib64/libc.so.6(+0xf8050)[0x2ace83113050] /lib64/libc.so.6(+0xf75a9)[0x2ace831125a9] /lib64/libc.so.6(_IO_default_xsputn+0x89)[0x2ace83090729] /lib64/libc.so.6(_IO_vfprintf+0x1b33)[0x2ace830647e3] /lib64/libc.so.6(__vsprintf_chk+0x88)[0x2ace83112638] ./a.out[0x4062f5] ./a.out[0x4051f9] ./a.out[0x411632] ./a.out[0x402794] ./a.out[0x4026de] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2ace8303b6e5] ./a.out[0x4025e9] ======= Memory map: ======== 00400000-004b0000 r-xp 00000000 00:2e 97121 [PATHNAME]/a.out 006af000-006b0000 r--p 000af000 00:2e 97121 [PATHNAME]/a.out 006b0000-006b3000 rw-p 000b0000 00:2e 97121 [PATHNAME]/a.out 006b3000-006d1000 rw-p 00000000 00:00 0 0211a000-0213b000 rw-p 00000000 00:00 0 [heap] 2ace826da000-2ace826fb000 r-xp 00000000 09:01 525333 /lib64/ld-2.22.so 2ace826fb000-2ace826fd000 rw-p 00000000 00:00 0 2ace82730000-2ace82734000 rw-p 00000000 00:00 0 2ace828fa000-2ace828fb000 r--p 00020000 09:01 525333 /lib64/ld-2.22.so 2ace828fb000-2ace828fc000 rw-p 00021000 09:01 525333 /lib64/ld-2.22.so 2ace828fc000-2ace828fd000 rw-p 00000000 00:00 0 2ace828fd000-2ace829f9000 r-xp 00000000 09:01 579040 /lib64/libm-2.22.so 2ace829f9000-2ace82bf8000 ---p 000fc000 09:01 579040 /lib64/libm-2.22.so 2ace82bf8000-2ace82bf9000 r--p 000fb000 09:01 579040 /lib64/libm-2.22.so 2ace82bf9000-2ace82bfa000 rw-p 000fc000 09:01 579040 /lib64/libm-2.22.so 2ace82bfa000-2ace82c12000 r-xp 00000000 09:01 525357 /lib64/libpthread-2.22.so 2ace82c12000-2ace82e11000 ---p 00018000 09:01 525357 /lib64/libpthread-2.22.so 2ace82e11000-2ace82e12000 r--p 00017000 09:01 525357 /lib64/libpthread-2.22.so 2ace82e12000-2ace82e13000 rw-p 00018000 09:01 525357 /lib64/libpthread-2.22.so 2ace82e13000-2ace82e17000 rw-p 00000000 00:00 0 2ace82e17000-2ace82e19000 r-xp 00000000 09:01 579038 /lib64/libdl-2.22.so 2ace82e19000-2ace83019000 ---p 00002000 09:01 579038 /lib64/libdl-2.22.so 2ace83019000-2ace8301a000 r--p 00002000 09:01 579038 /lib64/libdl-2.22.so 2ace8301a000-2ace8301b000 rw-p 00003000 09:01 579038 /lib64/libdl-2.22.so 2ace8301b000-2ace831b4000 r-xp 00000000 09:01 579034 /lib64/libc-2.22.so 2ace831b4000-2ace833b4000 ---p 00199000 09:01 579034 /lib64/libc-2.22.so 2ace833b4000-2ace833b8000 r--p 00199000 09:01 579034 /lib64/libc-2.22.so 2ace833b8000-2ace833ba000 rw-p 0019d000 09:01 579034 /lib64/libc-2.22.so 2ace833ba000-2ace833be000 rw-p 00000000 00:00 0 2ace833be000-2ace833d4000 r-xp 00000000 09:01 525376 /lib64/libgcc_s.so.1 2ace833d4000-2ace835d3000 ---p 00016000 09:01 525376 /lib64/libgcc_s.so.1 2ace835d3000-2ace835d4000 r--p 00015000 09:01 525376 /lib64/libgcc_s.so.1 2ace835d4000-2ace835d5000 rw-p 00016000 09:01 525376 /lib64/libgcc_s.so.1 7ffe53db0000-7ffe53dd2000 rw-p 00000000 00:00 0 [stack] 7ffe53de4000-7ffe53de7000 r--p 00000000 00:00 0 [vvar] 7ffe53de7000-7ffe53de9000 r-xp 00000000 00:00 0 [vdso] ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] forrtl: error (76): Abort trap signal Image PC Routine Line Source a.out 00000000004767ED Unknown Unknown Unknown a.out 0000000000474687 Unknown Unknown Unknown a.out 00000000004312D4 Unknown Unknown Unknown a.out 00000000004310E6 Unknown Unknown Unknown a.out 0000000000405F76 Unknown Unknown Unknown a.out 0000000000409B68 Unknown Unknown Unknown Unknown 00002ACE82C0AB10 Unknown Unknown Unknown libc.so.6 00002ACE8304F8D7 Unknown Unknown Unknown libc.so.6 00002ACE83050CAA Unknown Unknown Unknown Unknown 00002ACE8308D1B4 Unknown Unknown Unknown libc.so.6 00002ACE83114DC7 Unknown Unknown Unknown Unknown 00002ACE83113050 Unknown Unknown Unknown Unknown 00002ACE831125A9 Unknown Unknown Unknown libc.so.6 00002ACE83090729 Unknown Unknown Unknown libc.so.6 00002ACE830647E3 Unknown Unknown Unknown libc.so.6 00002ACE83112638 Unknown Unknown Unknown a.out 00000000004062F5 Unknown Unknown Unknown a.out 00000000004051F9 Unknown Unknown Unknown a.out 0000000000411632 Unknown Unknown Unknown a.out 0000000000402794 MAIN__ 6 test11.f90 a.out 00000000004026DE Unknown Unknown Unknown libc.so.6 00002ACE8303B6E5 Unknown Unknown Unknown a.out 00000000004025E9 Unknown Unknown Unknown
I am not sure if this is a compiler bug or a problem with my local environment. If this can be confirmed as a bug, I might try to submit a report to Intel.
Best regards
Ferdinand
Update: The crash seems to occur more generally in any situation in which an open-statement on a long filename runs into a (recoverable) error that is reported via iomsg.
@Ferdinand T.,
Intel now expects you to submit an incident on all their product-related issues at their Online Service Center (OSC):
