OUTPUT FILE AS A INPUT FILE IN SAME FORTRAN PROGRAM
uddin__md
Hi, I am a new user of FORTRAN language.  I write a program for index calculation. My program contains with 10 subroutines. First  9 subroutines produced an output file. I want to use first output file as an input file for the last one subroutine in same program.
How can I write this input and read command.
please, support me.
Arjen_Markus
The simplest way to achieve this is:
  • Write all the output to the output file
  • Close the file when you are done (so when the ninth subroutine as finished)
  • Then open it again, now you can read it from the start
Something like:
real :: x
open( 10, file = 'result.out' )
write( 10, * )  cos(1.0)
close( 10 )
read( 10, * )  x
close( 10 )
write( *, * ) 'The number that was produced is ', x
Arjen_Markus
Something like:
real :: x
close( 10 )
read( 10, * )  x
close( 10 )
uddin__md
Many thanks @Arjen Markus. I have been solved my problems as per following your guidelines.
