29530 Discussions
Observation: If ONLY used in subroutine then variables will NOT display in DEBUG
bmchenrync
I was having issues with being able to view variables in Debug in VS 2022 v 2026 in certain subroutines
and couldn't figure out why?
did the ole 'all CAPS' but didn't fix it...
and then i noticed/discovered that
in VS 2022/2026
IF you use ONLY to specify the ONLY variables in a MOD used in a subroutine
then in DEBUG
VS will NOT display the variable value and in Watch window is will say undefined!
Once i commented out all ONLY specifications
Then ALL variables used in the subroutine reveal their values!
strange?
Or is this the appropriate behavior with 2026/2022
bmchenrync
With update out and some folks saying things not working and since i started this topic
I tested (why not gamble, eh?!)
DEBUG WATCH/CHECK VARIABLE VALUES WORK
Test run on my win10 computer (so expect all will work on my win11 computer too which i will check later or tomorrow)
  • Visual Studio 2026 18.5.2
  • INTEL Fortran 2026.0.0.566
  • FEE_VSIX_V17
A right mouse hover over a variable produces variable value if Module without USE statement
Module name::Variable lists value in watch window for Modules with USE statement
BRAVO!
Great work INTEL!
Steve_Lionel
You should be able to click in the three dots in the upper right of your post and select Edit.
bmchenrync
unfortunately not on my menu by the 3 dots when logged in
