On default initialization
John4
Valued Contributor I
Even though, in light of recent threads, the code is not useful, I was wondering: why, in the following code, the compiler reports missing initialization, when the field is already initialized?
module mod1
    type :: t1
        integer :: i = 0
    end type
    type :: t2
        type(t1) :: a
    end type
contains
    subroutine do_something()
        type(t2), allocatable :: t(:)
        allocate (t(1:0))
        t = [t, t2()]
    end subroutine
end module mod1
The definition of the type of the component is always available (as opposed to what might happen with the interface of a function or subroutine), so it could just check its initialization as well (and save the extra "= t1()" required in the declaration of the component). Or am I missing something obvious?
An interesting case. I'm used to seeing issues like this with extended types, but that's not what we have here.
The standard says, regarding structure constructors:
C491 (R455) A component-spec shall be provided for a nonallocatable component unless it has default initialization or is inheritance associated with a subcomponent of another component for which a component-spec is provided.
Inheritance association is not relevant as this is not an extended type.
In your example, component a doesn't have default initialization. It is true that the type of a does have such for its components, but the standard doesn't consider that - at least I can't find words to say that it does.
I note that gfortran accepts your source without comment. I am going to check with the standards committee members just to make sure my understanding is correct.
On further research, this is our bug and I will let the developers know. a does indeed have default initialization due to the subcomponents being initialized. Issue ID is DPD200361914.
John4
Hi Steve,
The definition of t2 doesn't involve any structure constructor, so the constraint you mentioned (C492, in my copy of the standard) doesn't apply ---it applies in line 17, though.
In paragraph 7 of section 4.5.4.6 of the standard, I read:
7 A subcomponent (6.4.2) is default-initialized if the type of the object of which it is a component specifies default
initialization for that component, and the subcomponent is not a subobject of an object that is default-initialized
or explicitly initialized.
Which, to me, implies that the default initialization should apply for a%i, as you just confirmed. Thanks for clarifying the issue.
I wasn't concerned with the definition of t2, just the structure constructor. The text you cite is not quite relevant, it is sort of the reverse direction. It's paragraph 8 which has the appropriate text:
A type has default initialization if component-initialization is specified for any direct component of the type. An object has default initialization if it is of a type that has default initialization.
John4
The thing is, the error goes away if I define t2 as:
    type :: t2
        type(t1) :: a = t1()
    end type
So, to me, it means that the compiler is only checking if the initialization of the (non-allocatable) components in t2 is explicit ---that's why, in my original post, I suggest that the compiler could check the definition of t1 as well, to save on the extra " = t1()".
Anyway, it seems like it's still a bug.
What the compiler is missing is the nested property of default initialization. It's a simple thing we overlooked and will fix it.
