OneAPI, cannot find setvars.sh
mark10
I have installed OneAPI Linux 64 2022.0.2 base toolkit and hpc toolkit on Ubuntu 22.04, the installation instructions say to run the env script "setvars.sh" which is supposed to be located in /opt/intel/oneapi/ but it is not there and I can't find it anywhere on my system.
In addition when attempting to compile and link a hello world using ifort, I run into various issues which may be related:
ld: cannot find -limf
ld: cannot find -lsvml
Thanks for any help.
Ron_Green
Ubu 22.04 is not supported BUT I am surprised.  It appears to be a bad installation if that file is missing.
So I'd try to uninstall everything and start over.
The installer keeps a database.  It is kept in ~/intel folder.  So if you want to remove all installation history, do this:
rm -Rf ~/intel
assumes of course that YOU have not stored any of your own files in ~/intel
OK so now there is no history of your installation.  Now you can remove the binaries
rm -Rf /opt/intel/oneapi
There are 2 ways to install:  online or offline.  Which did you do?  If offline, check the checksums to make sure your download was not corrupted.   You might want to try just installing the components you want, from this article
Ubu 22.04 is new. and it's not officially supported.  There is a possibility this latest Ubu breaks something in the installer.  Let me know if the reinstallation is still missing setvars.sh.  it is critical to run this, the enviroment for oneAPI is complex.
You can set env for just the compiler with
source /opt/intel/oneapi/compiler/latest/env/vars.sh intel64
Ron_Green
rm -Rf ~/intel
mark10
Thank you, Ron, that worked.
Not sure what the problem was, in my initial install I used apt files, this time though I chose to use the Online installer GUI.
