29285 Discussions
OpenMP with libs:static cause memory leak
EruditePig
Here is the code:
    program main
    implicit none
    integer                         :: i
    type Element
        real(8),allocatable         :: eForce(:)
    end type Element
    type (Element),allocatable      :: elems(:)
    allocate(elems(100))
    !$omp parallel do private (i) schedule (guided)
    do i=1,100
        allocate(elems(i)%eForce(1000000))
        elems(i)%eForce=1.
    end do
    !$omp end parallel do
    write(*,*) "befor clean..."
    do while (.true.)
        write(*,fmt='(a,\)') "input 1 to continue:"
        read(*,*) i
        if(i.eq.1) exit
    end do
    deallocate(elems)
    write(*,*) "clean finished..."
    do while (.true.)
        read(*,*) i
        if(i.eq.1) exit
    end do
    end program main
If I choose "Debug Multithreaded (/libs:static /threads /dbglibs)" in project property, after clean the allocated memory, the memory usage is still near 1GB
However, If I choose "Debug Multithread DLL (/libs:dll /threads /dbglibs)", deallocate will perform right.
I notice that IVF stop support for static link of OpenMP (https://community.intel.com/t5/Intel-Fortran-Compiler/Intel-Fortran-Static-Library-with-OpenMP-enabled/td-p/1014804)
According to the thread, Am i wrong to choose the libs:static option?
The Intel Fortran version I used is 19.1.0.166
Steve_Lionel
/libs:static doesn't affect the OpenMP library, which is DLL-only. Have you tried a more recent compiler and runtime library?
EruditePig
the attachment is the solution, The Intel Fortran version I used is 19.1.0.166 , the VisualStudio version is 16.9.0
Both are recent updated software
Steve_Lionel
I can reproduce the difference using the 2021.0.2 compiler and libraries. What causes it, I don't know., but I do know that there can sometimes be issues mixing DLL and static linked code. If you have paid support I suggest you report this through the Intel Online Service Center. But the most pragmatic approach would be to use DLL linking, which is the default.
JohnNichols
Valued Contributor III
Why is the default dll, it makes a lot more sense to bind in the lib.
Steve_Lionel
Linking to DLL libraries saves space, reduces memory load, and allows for DLLs to be updated without requiring a relink. Microsoft changed its defaults many years back to default to DLL linking. In the case of OpenMP, I recall a claim that there were run-time issues caused by use of a static library for OpenMP. I don't recall the details, and note that a static OMP library is still provided on Linux, but that is a different environment.
JohnNichols
but in the days of Microsoft Fortran you created a single file that sat on a floppy and just ran, now it is a convoluted set of dlls.  Bring back MS Fortran V 3.03 and twin floppy drives, the modern youth are spoiled.
