Optimization bug in 12.0.3?
konstantin83
I've recently found something that looks like a compiler bug to me. I'm using ifort 12.0.3.174 and the bug is there when -O3 option is used. This is the simplest version of the program that has it, I hope it is self-explanatory: the value of 'index' variable at the end should be 1, but it is 0 instead with -O3 option. Everything works correct if the module aux_mod is defined in the same file as the main program or if I do not call the subroutine.
main.f90
aux_mod.f90
Ron_Green
I will investigate, find what version this first showed itself, and get a bug report going.
ron
Ron_Green
bug ID is DPD200170206
affects all versions of 12.x. Does not affect older 11.1 compiler versions.
ron
Ron_Green
This bug was fixed in recent 12.1 compilers released after December 2011.
closing.
ron
