Optimization flags
Zuheyr_A_
I am using Ubintu Linux 8.10,
~$ uname -a
Linux zuheyr-desktop 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:06 UTC 2008 x86_64 GNU/Linux
The processor is Intel Core 2 Duo, Dell Inspiron 530S desktop. I am using
~$ which ifort
/opt/intel/fce/10.1.018/bin/ifort
I would greatly appreciate if I can figure out the best optimization flags for the fortran compiler
which still retains the numerical accuracy. I am doing benchmarks and it is running much slower than lahey fortran 64 bit compiler...
Many thanks for reading, Regards, Zuheyr
TimP
It would help if you would divulge which options you use on the 2 compilers, how critical you are about accuracy, and what kind of operations you want to speed up.
'ifort -xP -O3 -parallel -assume protect_parens,buffered_io' usually works well. It is certainly possible to find benchmarks which run faster at -O1.
Current ifort has some improved optimizations.
Zuheyr_A_
Quoting - tim18
Thank you very much. I am using -O3 for both. When I used the options you suggested I got the following error message:
../../PROGRAM/hyp_grid-if.exe: error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
Many thanks for your time. Regards, Zuheyr
Zuheyr_A_
Hi again, furthermore, when I removed the -parallel option, it just crashed at some point with the error
segmentation fault.
When I use -O3 it is working.
Thank you again, Regards Zuheyr
TimP
When you set -parallel or -openmp, or link in libraries built with similar options, libiomp will be required at run time. Then it is doubly important to set LD_LIBRARY_PATH (e.g. by running the ifortvars script in the same directory as ifort).
kiran_nalawade
You are not setting the library path .. just look for the proper one ..
