The following code does not compile with Intel Fortran v16, v17, on x86-64 Linux:
module mymod implicit none type :: mytype private integer :: a contains procedure,private :: eq generic :: operator(==) => eq endtype mytype interface mytype module procedure :: constructor endinterface mytype contains type(mytype) function constructor(a) integer,intent(in),optional :: a if(present(a))then constructor % a = a else constructor % a = 0 endif endfunction constructor logical function eq(m0,m1) class(mytype),intent(in) :: m0 class(mytype),intent(in) :: m1 eq = m0 % a == m1 % a endfunction eq endmodule mymod module wrapper_module use mymod,only:mytype endmodule wrapper_module program test use wrapper_module implicit none write(*,*)mytype() == mytype(0) endprogram test
The compiler does not seem to resolve the overloaded == operator for mytype:
$ ifort test.f90 test.f90(44): error #6355: This binary operation is invalid for this data type. write(*,*)mytype() == mytype(0) ----------^ test.f90(44): error #6355: This binary operation is invalid for this data type. write(*,*)mytype() == mytype(0) ----------------------^ compilation aborted for test.f90 (code 1)
If the main program accesses mytype directly from mymod, the program compiles and executes as expected.
If the main program accesses mytype from wrapper_module, and wrapper module accesses mytype via "use mymod", the program compiles and executes as expected.
If the main program accesses mytype from wrapper_module, and wrapper module accesses mytype via "use mymod,only:mytype" (the example code above), the compilation fails with the above message. I think this is unexpected behavior.
The code compiles and executes as expected when compiled with gfortran 5.x
milan
Thanks - this is an issue we're already working on. Issue ID is DPD200374263.
Just a follow-up, the issue remains as of Intel Fortran 19.0.1.144 Build 20181018.
Cheers,
milan
This still seems to be present even in the latest compiler. Any updates on the Intel side?
For me this works with ifort v19.0.3 and v19.0.4 as well as with the beta version of 19.1.0. So it seems that this bug has been fixed.
Thanks Juergen, it looks like it's time for an update. :)
