Overloaded structure constructors get distracted by abstract
IanH
I think this has been around for a little while, but the new version prompted me to flush it out.
MODULE MA
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: t
  TYPE :: t
    INTEGER :: comp
  END TYPE t
  INTERFACE t
    MODULE PROCEDURE Make_t
  END INTERFACE t
CONTAINS
  FUNCTION Make_t(arg)
    REAL, INTENT(IN) :: arg
    TYPE(t) :: Make_t
    Make_t%comp = NINT(arg)
  END FUNCTION Make_t
END MODULE MA
PROGRAM PB
  USE MA
  IMPLICIT NONE
  ABSTRACT INTERFACE
    SUBROUTINE s
      USE MA      ! #A comment me out and all is well.
    END SUBROUTINE s
  END INTERFACE
CONTAINS
  SUBROUTINE internal_or_module
    ! USE MA      ! #B comment me in and all is well.
    TYPE(t) :: a
  END SUBROUTINE internal_or_module
END PROGRAM PB
>ifort /c /check:all /warn:all /standard-semantics DistractedByAbstract.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.108 Build 20140726
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
DistractedByAbstract.f90(30): error #6463: This is not a derived type name.
    TYPE(t) :: a
compilation aborted for DistractedByAbstract.f90 (code 1)
IanH
A different variant, with no interface block, that perhaps looks a bit like the one recently reported on the linux forum.  If either line marked #A is commented out then the error messages go away.
MODULE CmdLine
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: CmdLineOption
  TYPE :: CmdLineOption
    CHARACTER(:), ALLOCATABLE :: LongName
  END TYPE CmdLineOption
  INTERFACE CmdLineOption
    MODULE PROCEDURE CmdLineOption_all
  END INTERFACE CmdLineOption
CONTAINS
  PURE FUNCTION CmdLineOption_all(long_name) RESULT(clo)
    CHARACTER(*), INTENT(IN), OPTIONAL :: long_name
    ! Function result
    TYPE(CmdLineOption) :: clo
    IF (PRESENT(long_name))     clo%LongName = long_name
  END FUNCTION CmdLineOption_all
END MODULE CmdLine
MODULE ContexterTestImplementation
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: UsageMessage
CONTAINS
  SUBROUTINE UsageMessage(cmd_line_options)
    USE CmdLine
    TYPE(CmdLineOption), INTENT(IN) :: cmd_line_options(:)
    if (size(cmd_line_options) /= 0) continue  ! Just to get rid of warning.
  END SUBROUTINE UsageMessage
END MODULE ContexterTestImplementation
PROGRAM ContexterTest
  USE CmdLine
  USE ContexterTestImplementation                             ! #A
  IMPLICIT NONE
  TYPE(CmdLineOption) :: cmd_line_options(1)
  cmd_line_options(1) = CmdLineOption(LONG_NAME='help')
  CALL UsageMessage(cmd_line_options)                         ! #A
END PROGRAM ContexterTest
>ifort /c /check:all /warn:all /standard-semantics ContexterTest.f90
ContexterTest.f90(42): error #6463: This is not a derived type name.   [CMDLINEOPTION]
ContexterTest.f90(44): error #6404: This name does not have a type, and must have an explicit type.   [CMD_LINE_OPTIONS]
ContexterTest.f90(44): error #8213: A keyword in the structure constructor is not the name of a type component.   [LONG_NAME]
compilation aborted for ContexterTest.f90 (code 1)
So apparently its not a derived type name, but it is a structure constructor.  Cake, have, eat too.
Edit to note that a workaround appears to be to rename the type (and then use that new name) in the use statement of the main program.
