29386 Discussions
Overring intrinsic procedures with type bound procedures
Andrew_Smith
Valued Contributor I
In F2003 (not yet IVF) there is overiding for operators and assignment using type bound procedures but how about intrinsics?
When we have a type bound precedure we must call using % notation as below. But this will mean we do not overide the intrinsic. Or am I wrong?
MODULE x
TYPE y
REAL z
CONTAINS
PROCEDURE abs => ABS_a
END TYPE
CONTAINS
CLASS(y) FUNCTION ABS_a(me)
CLASS(y), INTENT(IN) :: me
ABS_a%z = ABS(me.z)
END FUNCTION
END MODULE
PROGRAM TEST
TYPE(y) a, b
a%z = -1.0
b = abs(a) !Illegal use of intrinsic abs
b = a%abs !Will use type bound procedure
END PROGRAM
IanH
I believe you are right. To actually "override" the intrinsic you would need to provide the usual generic interface. The specific procedure would be selected on the basis of the declared type of the argument. This specific procedure could then forward the call to the appropriate type bound procedure.
[fortran]MODULE x
  TYPE y
    REAL z
  CONTAINS
    PROCEDURE :: abs => ABS_a
  END TYPE
  ! So the intrinsic behaves like we'd expect.
  INTERFACE Abs
    PROCEDURE abs_forwarder
  END INTERFACE Abs
CONTAINS
  ! gets called when dynamic type of me is a y
  FUNCTION ABS_a(me) RESULT
    CLASS(y), ALLOCATABLE :: r
    ALLOCATE(y:: r)
    r%z = ABS(me%z)
  END FUNCTION
  ! gets called when declared type of me is a y
  FUNCTION abs_forwarder(me) RESULT
    ! polymorphic call to abs, which might go to ABS_a or equivalent override
    ! in an extension of y.  F2008 allows assignment here?
    ALLOCATE(r, SOURCE=me%abs)
  END FUNCTION abs_forwarder
END MODULE x
    [/fortran]
But don't be surprised if I'm totally wrong :).
Arjen_Markus
Why the allocate statements? Isn't the variable r that holds the function value already allocated?
Arjen
asymptotic
module module_x
implicit none
type, public:: y
real:: z
contains
procedure, pass:: abs => abs_a
end type
contains
type(y) function abs_a(me)
implicit none
class(y), intent(in) :: me
abs_a % z = abs(me % z)
return
end function
end module
program test
use module_x
implicit none
type(y):: a, b
a % z = -1.0
b = abs_a(a)
b = a % abs() ! type bound procedure
stop
end program
Andrew_Smith
It seams to me that it would have made sence if F2003 or F2008 said that intrinsic procedures should be callable as type bound procedures too, then we could all adopt the new % notation for calling stuff.
