Passing a null pointer to a subroutine fails with segv
Raghu_Reddy
! Compile and run using:
!  ifort optional-bug.f90
!  ./a.out
program option
  implicit none
  real, target  :: at, dt
  real, pointer :: ap, dp
  at = 10; dt = 40
  ap => at
  dp => dt
  dp => null()              ! Uncommenting this line crashes
  print*, 'before ap, dp', ap, dp
  call mysub(ap, dp)
  print*, 'after ap, dp', ap, dp
  contains
    subroutine mysub(aa, dd)
      real :: aa
      real :: dd
      aa = 1000.*aa
      print*, ' Inside mysub aa = ', aa
    end subroutine mysub
end program option
mecej4
I think that you are not interpreting the program behavior correctly. It is not the passing of a null pointer (for an argument that is not referenced) that causes the SEGV, but the referencing of the target in the two I/O statements.
Remove ", dp" from the two PRINT statements, and you will see that the program runs with no SEGV happening.
Raghu_Reddy
Thank you very much!  We missed that one!
Let me try the original code I started with, which had to do with optional arguments.  Thanks again!
