Passing an array from Fortran Function to JAVA, using JNA interface
miguel_campo
Hi all,
I am really new with java. I would like to call from java a DLL compiled in Fortran and obtein in java the result array.
I did with scalars and work well, but with array does not work.
I will explain with a simple example:
Fortran code, and compiled as DLL (F95Test.f)
function Proof(a)
!DEC$ ATTRIBUTES DLLEXPORT,ALIAS:"FProof" :: Proof
integer, value :: a
INTEGER, DIMENSION (a) ::Proof
integer::i
DO i = 1, a
Proof(i) = 300
END DO
end function Proof
Now from Java code:
package Component;
import com.sun.jna.*;
public class Union {
interface F95Test extends com.sun.jna.Library {
F95Test lib = (F95Test) Native.loadLibrary("C:/Flood/FloodProgram/FloodProgram/Debug/FloodProgram.dll",
F95Test.class);
int[] FProof (int b);
public static void main(String[] args) {
int[] result=F95Test.lib.FProof(2);
System.out.println(result);
When I try to run this code the message is:
Exception in thread "main" java.lang.IllegalArgumentException: Unsupported return type class [I in function FProof
at com.sun.jna.Function.invoke(Function.java:424)
at com.sun.jna.Function.invoke(Function.java:276)
at com.sun.jna.Library$Handler.invoke(Library.java:216)
at Component.$Proxy0.FProof(Unknown Source)
at Component.Union.main(Union.java:46)
So I do not know if someone have moved arrays from fortran to java. I would appreciate so much any idea.
Miguel
Steven_L_Intel1
Your Fortran function doesn't match the Java declaration. A Fortran function returning an array does so using a hidden first argument that is the return array. And in this case, where you declared it as being "adjustable" (with bounds specified by dummy argument a), Fortran expects that the caller has preallocated the return value array to that size and passed its address. I am not sure what the Java declaration means, but it certainly doesn't match.
Let me suggest that you stick to Fortran procedures that are "interoperable", which puts some restrictions on what the arguments and return value can be. Here, you may want to make it a subroutine and pass a preallocated array and the array size as arguments.
miguel_campo
That is true I was working in a wrong way.
With subroutines it works fine.
I copy both codes just in case it could be helpully for someone
! Prueba.f90
subroutine Prueba(arr, len)
!DEC$ ATTRIBUTES DLLEXPORT::Prueba
INTEGER, DIMENSION(len) :: arr
INTEGER, VALUE :: len
INTEGER:: i
DO i=1, len
arr(i)=arr(i)+30
END DO
write(*,*) arr(1)
end subroutine Prueba
From Java
package Component;
F95Test lib = (F95Test) Native.loadLibrary("C://Prueba/Prueba/Prueba/Debug/Prueba.dll", F95Test.class);
//------------Call Function/Subroutine as ARRAY ARGUMENTS---------------------
void PRUEBA(int[] arr, int len);
int[] a = {1, 2, 3, 4, 5};
int b=a[0];
System.out.println(b);
F95Test.lib.PRUEBA(a, a.length);
int b1=a[1];
System.out.println(b1);
Miguel
Sikha_r_
hello sir.
i want tocall fortan function in java..bt m geting error.
here is my code:
public class FortanJava {
    interface  F95 extends com.sun.jna.Library
        F95 test=(F95)Native.loadLibrary("F90Dyn", F95.class);
         int foomult(int a, int b);
     * @param args the command line arguments
        // TODO code application logic here
        int result = F95.test.foomult(5,5);
m getting error like this Java HotSpot(TM) 64-Bit Server VM warning: You have loaded library /tmp/jna5645755368766446105.tmp which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
