Passing an array of strings from VBA to Fortran DLL
cmc
I have difficulties getting the DLL to read my array of strings. The following declaration is given in VBA:
    Public Declare Sub fortran_dll Lib "path_to_dll" _
    (ByVal array1 As String, ByRef array2 As Integer, ByRef array3 As Double, _
    ByRef array4 As Integer, ByRef array5 As Double)
The following attributes are given in Fortran:
    !dec$ attributes dllexport, stdcall, reference, alias: "fortran_dll" :: fortran_dll
    !dec$ attributes reference :: input_characters, input_integers, input_reals
    !dec$ attributes reference :: output_integers, output_reals
Is there a guide or procedure for how to make this work? I manage to read the integers and doubles, so the trouble is only linked to the strings. Can anyone help me?
\Carl
Eugene_E_Intel
Please post some sample code that shows how you access the strings.
This thread has sample code for passing VBA strings to Fortran: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/393803
Arrays of strings would be more difficult, since VBA probably uses "SafeArray of BSTR" structure for array of strings.
DavidWhite
Valued Contributor II
I avoided the use of the BSTR structures in my application by concatentating all of the strings, and so only passing back a single string.  It needs to be a C string, e.g.
Str=CharOut(1)//CharOut(2)//CharOut(3)//CharOut(4)//CharOut(5)//''C
Eugene_E_Intel
How do you declare fortran_dll() and its parameters in Fortran?
cmc
Sample code:
!   declarations:
    character(len=256), intent(in) ::  input_characters(5)
!   input_characters:
    character(len=50)              :: file_1, file_2, file_3, file_4, file_5
!   assigning characters:
    file_1                         = input_characters(1)
    file_2                         = input_characters(2)
    file_3                         = input_characters(3)
    file_4                         = input_characters(4)
    file_5                         = input_characters(5)
I have tried different character lengths in the declaration, with no luck. This post (https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/391172) address the same issue I have, but I only see workarounds (e.g. write the strings to a text-file and read the strings from there), not an actual solution to the problem. I see "SafeArray of BSTR" is mentioned in both posts. Can someone explain to me how I do this? Does that mean I have to translate the string to ASCII or binary code and send that instead?
Eugene_E_Intel
If a single string is passed to a Fortran routine, then Fortran routine needs to read it as a single string, not as an array.
I suggest that in VBA you concatenate your array of strings into a one string, using end-of-line as a delimiter.  Pass this concatenated string to Fortran code, and then parse it into individual strings.
Handling SafeArray of BSTR from Fortran code would be very difficult.
--Eugene
