Passing array of characters from Fortran DLL to VBA
Lorenzo_W_
I am trying to link a Fortran DLL to VBA.
I started by using Intel example (https://software.intel.com/en-us/node/611723) and I am able to deal with all kind of data except array of strings.
Here is my example:
FORTRAN:
SUBROUTINE TESTARRAY (ELEMENTS, OUTARRAY) ! bind(c, name='TESTARRAY')
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, REFERENCE, ALIAS:"TESTARRAY" :: TESTARRAY
IMPLICIT NONE
INTEGER*4, INTENT(IN) :: ELEMENTS
CHARACTER*15, INTENT(OUT) :: OUTARRAY(ELEMENTS)
INTEGER*4:: I
!DEC$ ATTRIBUTES REFERENCE :: ELEMENTS, OUTARRAY
DO I = 1,ELEMENTS
    WRITE(OUTARRAY(I),'(I3.3)') I
ENDDO
RETURN
END SUBROUTINE TESTARRAY
VBA:
Option Explicit
Option Base 1
Dim arraytest() As String * 15
Declare Sub TESTARRAY Lib "PATH\MYDLL.dll" (ELEMENTS As Long, ByVal OUTARRAY As String)
Public Function array_dll(iel As Long) As String
   ReDim arraytest(1 To iel)
    Call TESTARRAY(iel, arraytest(1))
    array_dll = Trim(arraytest(iel))
End Function
When I try to use inside an Excel sheet the function "array_dll" linked to a cell containing for example "5", I obtain an empty cell, and not "005" as expected.
How is the right method for dealing with that kind of data?
Thank you!
DavidWhite
Valued Contributor II
For simple cases passing multiple strings (not just arrays), I have sometimes just concatenated the strings on the VBA side and then unpacked them on the DLL side. (and of course, the reverse for passing the strings back).
Steve_Lionel
There is a complete example VB.NET-Safearrays in the Intel sample bundle that demonstrates doing exactly this. It's a lot more complicated than what you show above.
Lorenzo_W_
Thank you for the hint.
It is a lot more complicated than I thought, maybe I should try a workaround.
Thank you again
FortranFan
Lorenzo W. wrote:
.. It is a lot more complicated than I thought, maybe I should try a workaround ..
@Lorenzo W.,
How is the actual argument (i.e., the object equivalent to arraytest in your example above) used in the VBA code?  Specifically, does it have to be an array?
DavidWhite
Lorenzo_W_
Dear all,
I think that I can re-think about my output.
As David White suggested me, the best think I can do is to concatenate and then unpack strings, it is more simple than all other solutions.
Thank you all
