29280 Discussions
Passing assumed-shaped arrays from Fortran(g95) program to a Fortran(Intel) dll
galatyp
The code below is the main program (compiled withanother fortran compiler)calling a function in a dll which is compiled with Intel Fortran Compiler.
Code:
PROGRAM prgSample
 interface
    function DllFunc(Array)
      Real(4),intent(in) :: Array(:)
      Real(4) :: DllFunc
    end function
  end interface
  Real(4)::Array(10),DllReturn
  Array=0
  DllReturn=DllFunc(Array)
  PRINT*,'Size of Array: ',DllReturn
END PROGRAM prgSample
this is the code of the dll function (compiled with Visual Fortran)
Code:
implicit none
  Real(4) :: DLLFUNC
  DllFunc=Size(Array)
end function
when i run the program, it prints "Size of Array: 4" although it's 10.
if i compile the dll with same compiler it works. Is there any possibility of array descriptor structure of the compilers wouldn't be same ?
Or maybe, Visual Fortran compiler default expects a normal array reference not a descriptor reference from the outside calls ?
I'm really stuck here therefore any help would be great. Thanks in advance.
The array descriptors are not the same. Close, but not compatible. An alternative is to pass the array length as a separate argument and use "adjustable arrays" such as this:
function DllFunc(Array,N)
implicit none
Integer(4), intent(in) :: N ! Must be declared first!
Real(4),intent(in) :: Array(N)
Real(4) :: DLLFUNC
DllFunc=Size(Array)
end function
