Visual Fortran dialog box
ekeom
I would like to write an interactive program, as show in the example.
program xxx
i = function of some parameters
if(i>0) then
display message & dialog box
' (i>0) do you want to continue '
(click - YES or NO - )
if YES jump to continue label
if NO execution if interruted
endif
continue
end xxx
Can someone help for this. Thank you for Your help.
Didace
anthonyrichards
New Contributor III
Use MESSAGEBOX, which you will find in module USER32,
which can be obtained by adding USE DFWIN to your
calling code
use dfwin
use dfwinty ! loads parameter definitions
! for MB_YESNOCANCEL, IDYES etc.
integer hWnd ! hWnd Can be NULL
integer iret
character*100 lpszMessage, lpszHeader
if( i.gt.0) then
lpszMessage = "(I>0), Do You want to continue"C
lpszHeader = "ERROR MESSAGE"C
! If hWnd is null, the message box has no owner window...
iret = MessageBox (hWnd, &
lpszMessage, & lpszHeader, & IOR(MB_SYSTEMMODAL, & IOR(MB_YESNOCANCEL)) ) endif
if(iret.eq.IDCANCEL) then
else if(iret.eq.IDYES) then
else if (iret.eq.IDNO) then
endif
Message Edited by anthonyrichards on 08-26-2005 02:57 AM
ekeom
Thank you very much anthonyrichards for your answer.
Didace
