29648 Discussions
Passing slice of array pointer to sub
csh1
I am compiling a large code that expects to be able to send a slice of an array pointerinto a subroutine. See simple example attached.
[vb]real, pointer :: a(:)
! allocate, assign a, etc., then
call sub(a(4), 3)
[/vb]
with the intent of sending an array of 3 values starting at a(4) into the subroutine.
Compiler is giving me this error:
error #7836: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element. C:\HTC\TestBench\TestCompiler\TestCompiler\TestCompiler.f9033
However, if I create an array slice it works fine
[cpp]real, pointer :: tmp(:)
tmp => a(4:6)
call sub(tmp, 3)
[/cpp]
Is this a bug or a feature?
Feature - of the Fortran language. You are trying to use "sequence association" but that is not available for POINTER arrays because pointers can point to discontiguous memory. Make the array ALLOCATABLE instead and it will work.
csh1
I tried to add the example source file but it didn't show up in my post. Here it is
[cpp]    program TestCompiler
    implicit none
    integer :: i
    real, pointer :: a(:), tmp(:)
    allocate(a(10))
    do i = 1,10
     a(i) = i
    enddo
    print *, a
    ! pause
    read(5,*) i
!   fails
!   call sub(a(4),3)
!   works
    tmp => a(4:6)
    call sub(tmp,3)
    ! pause
    read(5,*) i
    contains
    subroutine sub(x,n)
      integer :: n
      real :: x(n)
      print *, x
    end subroutine sub
    end program TestCompiler
[/cpp]
