29375 Discussions
Pb in Debugger for checking derived types with pointer arrays put in COMMON
ESTIENNE_j_
I am not sure the pb is connected with one bug referenced on variables in the debugger. When defining a derived type in an include file so as:
INCLUDE File INC.F
TYPE T_SVD
SEQUENCE
INTEGER MxI,MxJ,MxK
COMPLEX,POINTER:: U(:,:),V(:,:),Z(:,:)
REAL,POINTER:: S(:)
END TYPE
TYPE
T_CBD
SEQUENCE
TYPE(T_SVD),POINTER:: R(:),Q(:)
TYPE(T_A),POINTER:: P(:)
END TYPE
COMMON/
COM_Blck/Blk,CBD,CBI
and using the values in a routine as follows
SUBROUTINE Test(...)
INCLUDE 'Inc.F'
ALLOCATE(Temp(CBD.R(p).MxK,CBI.Gamma(p).MxK))
Temp=MATMUL(TRANSPOSE(CBD.R(p).U),CBI.Gamma(p).U)
FORALL(k=1:SVD1.Mxk) Temp(k,1:)=CBD.R(p).S(k)*Temp(k,1:)
FORALL(k=1:SVD2.Mxk) Temp(1:,k)=CBI.Gamma(p).S(k)*Temp(1:,k)
CBI.Pi(i).Z=CBI.Pi(i).Z-
RETURN
END
the debugger says CBD is an undefined variable, although I know it is correctly allocated & working
The containt of CBD; for example CBD.R, ...cann't also inspected with the debugger. If such a type is definedinternally in the subroutine, it works correctly
Please answer
Thanks for your help
Please report such problems to Intel Premier Support.
jimdempseyatthecove
Your Inc.F has a type T_CBD and a common for CBD but no declaration of CBD
type(T_CBD) :: CBD
Jim
ESTIENNE_j_
Sorry, I forgot it here, but this declaration is inside the code which doen't work. So this is not the problem
