Pointer behavior in procedure
OP1
New Contributor III
Consider the two following examples:
SUBROUTINE S1
IMPLICIT NONE
INTEGER, POINTER :: P(:)
ALLOCATE(P(10))
END SUBROUTINE S1
SUBROUTINE S2
IMPLICIT NONE
INTEGER, ALLOCATABLE :: TEMP(:)
ALLOCATE(TEMP(10))
P => TEMP
END SUBROUTINE S2
Is it correct to say that S1 leads to a memory leak whereas S2 does not?
IanH
Yes.
(The TARGET attribute needs to be added to TEMP in S2.)
OP1
New Contributor III
Ooops, yes I forgot TARGET (I didn't try to compile those two examples, hence the miss).
Thanks for confirming my understanding of this though! Very much appreciated.
